Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-22-2009, 09:14 AM
maxell3655's Avatar
maxell3655 maxell3655 is offline
maxell3655 is starting off with a positive reputation.
92 f250 460 timing question
I had advanced the timing on my 1992 f250 with a 460 from the stock 10 degrees to 12 or 13 degrees. Not sure which one for sure cause it is a little hard to tell. Anyways after i did it my acceleration was faster then usual as expected. Even sucked me into my seat when i hammered it at 40k and let off at 80k a few seconds later.
So the problem is that my computer had reset itself and adjusted the fuel and i was wondering what i can do to set it back. The power was impressive and i wouldnt mind having it back. Now it feels that i am back to where i started. Any help would be great.
__________________
1992 Ford f250 HD 3.55's open end, e40d, ext cab longbox, lt235/85r16, factory 460, thrush glasspack exhaust 3" inlet dual 2.5" outlet, access tonneau cover, +390,000 kms on original motor going up daily.
  #2 (permalink)
Old 06-26-2009, 02:04 PM
The "Mad Porter" The "Mad Porter" is offline
The "Mad Porter" is starting off with a positive reputation.
Did you disconnect the pip connector when you set the timing?
__________________
Regards,
Scott J. / The Mad Porter.
'06 Engine Masters 3rd place finisher.
RHP
Tacoma, WA.
  #3 (permalink)
Old 06-30-2009, 12:30 AM
maxell3655's Avatar
I justed turned the distributor. Never touched anything else
__________________
  #4 (permalink)
Old 06-30-2009, 12:07 PM
Then the ecm just reset the timing back to what ever it was. You need to disconnect the little grey pip connector near the TFI modle be it on the distributor or the drivers fender near the firewall. Set the timing then reconnect the pip connector. The check engine lite will come on but will go out when you restart.
__________________
Regards,
RHP
Tacoma, WA.
  #5 (permalink)
Old 07-04-2009, 12:51 AM
maxell3655's Avatar
Thanks. I will do that and see what happens.
__________________
Tags
1992 , 460 , 92 , advance , f250 , timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
