Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-22-2009, 08:33 AM
PRL PRL is offline
PRL is starting off with a positive reputation.
Rocker noise
I've done some research on line, and cannot find what this problem is. When I drive on the highway at 100 km/h for 30 minutes I start to hear my rockers clatter. At first my oil pressure would drop at the same time, but since doing an engine flush with sea foam and changing the oil and the pcv the oil pressure now doesnot fall as noticeably. I'm wondering where the preblem would be? My suspicions are the oil pump or the lifters, but I'm not very good at trouble shooting.
Thanks in advance for any help I receive.
  #2 (permalink)
Old 06-22-2009, 09:18 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
You may have knocked some hardened gunk loose which is now partially blocking the oil pickup, time to drop the pan before the whole motor lets go.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, 1.6 RR, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, and now power steering!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
