Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 06-24-2009, 11:45 PM
75F350's Avatar
75F350 75F350 is offline
1973 Ford F-100
My Garage
75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE.
Where did you find headers that fit a truck application and had the same pattern that you required? Port location is dofferent on these heads and since you were talking about making more power, I believe that you have left some performance on the table using these in this application.
  #17 (permalink)
Old 06-25-2009, 12:16 AM
1969Highboy 1969Highboy is offline
1969 Ford F-250
1969Highboy is starting off with a positive reputation.
Quote:
Well technicall we didn't find headers for them, we just got a 390 set and drilled some holes in the headers (not as easy as you would think) and how did i leave performance on the table? with the heads, or the headers?
  #18 (permalink)
Old 06-25-2009, 12:49 AM
75F350's Avatar
1973 Ford F-100
My Garage
There is some power left on the table because of the port size. You have noticed the differences in sizes, and acknowledged that you had not match ported yet, so there is some power on the table, most are not aware of the exhaust port location difference between the std FE heads and some of the more desirable heads, and especially the more rare heads.
While your set up runs, and will run, it wont run to its full potential, unless you have this thing in the 6K rpm range all of the time, and even then it is not optimum because the air become turbulent and simply cant flow with a restriction. The exhaust port difference is almost .250". This is a fair amount of obstruction.
I do not even know which set of heads you have, so this is all speculation, but I do remember the mention of more power, and more power is right there.
  #19 (permalink)
Old 06-25-2009, 01:09 AM
1969 Ford F-250
So all I have to do is port the ports on the intake right? With the headers, the ehaust ports and the headers match up really close. but the intake ports on the intake are atleast a quarter inch smaller than the intake ports on the heads. So how much more power do you think that would add?
  #20 (permalink)
Old 06-25-2009, 01:19 AM
75F350's Avatar
1973 Ford F-100
My Garage
This is a double edged sword here, because the larger port generally slows air speed and velocity, so throttle response and low rpm suffers. That being said, opening any ports further can exadurate this problem.
DO you have a casting number for the heads that you actually have? I only know them as a 14 Bolt exhaust, and this covers several. Some were better than others.
Either way, a decent match port should always be done, without making the intake port on the head any larger unless it is valuable to increase its size.
  #21 (permalink)
Old 06-25-2009, 02:44 AM
Prozon's Avatar
Prozon Prozon is offline
1988 Ford F-350
Prozon is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by 1969Highboy View Post
I rarely go off-roading, if I do, it's just down a low maintenance road or in a plowed field, no jumps, no bumps, no stumps. It's more for driving through town and lookin good, I hate cleanin it and stuff breaks so much easier if you go mudding a lot. But about the headers, I got some exhaust yesterday and now I can here a few header leaks so when I'm bored I got to snug up the bolts, I got 14 bolt heads so it takes awhile.
I thought it was a little too shiny.
Its a good looking truck all-in-all. I had my truck running straight out of the manifolds, (not driving it around obviously) because my new high torque starter gets in the way of things.
It sounded decent, but as soon as I got my pipe bolted back up it sounds so much better. (No mufflers or anything atm.)
__________________
1988 Ford F-350 460ci EFI
37" Super Swampers - Warn Winch
F-350 Planning Thread
  #22 (permalink)
Old 06-25-2009, 09:42 AM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel is gaining momentum as a positive member of FTE.
What size of carb are you running? I've talked to a guy in town here that builds FE motors, one of his cars puts around 800 hp to the ground. I dont know what size he was running, but he wanted to put a 900 or 950 cfm on my 351M. he said most people run too small of carbs on FEs, 351M/400, and 351Cs.
__________________
my supermotors page http://www.supermotors.net/users/hav24wheel
78,85,92 Ford
Just bought a 94 F-150
  #23 (permalink)
Old 06-25-2009, 07:29 PM
1969 Ford F-250
The heads I have are C6AE-8090R, I think thats the right one?
Prozon- and oh its not too shiny haha, i just got to keep it clean so she doesn't rust away
hav24wheel- I'm running a holley 4160, 750 double pumper so I think i'm gettin enough fuel, it goes through a tank to fast i hope i dont need bigger haha. But yeah i hear it all the time that people with FE's that they shouldn't go much over 600 or 650cfm.
  #24 (permalink)
Old 07-02-2009, 12:19 AM
1969 Ford F-250
And my bad, they aren't 14 bolt exhaust, they are 16 bolt exhaust heads
  #25 (permalink)
Old 07-02-2009, 02:48 AM
75F350's Avatar
1973 Ford F-100
My Garage
Big difference there.
You have CJ heads, not GT heads.
  #26 (permalink)
Old 07-02-2009, 03:20 AM
1969 Ford F-250
yeah, i thought 14 cuz that was what the first set was, than we bought another set, so being the CJ, i'm assuming much better right?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
