Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-22-2009, 12:17 AM
Walking Hill Walking Hill is offline
Walking Hill is starting off with a positive reputation.
89 BII Gas Gauge
I'm looking to buy a BII. The gas gauge is out. How would I go about fixing that.
  #2 (permalink)
Old 06-23-2009, 09:01 AM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
First, check the wiring from the instrument cluster to the fuel tank sender... more than likely, if all the other gauges are working, then the in-tank sender is bad. That requires the tank to be drained and dropped, unless you feel like cutting a hole in the floorpan of the cargo area. This is a common issue with the 80s Ranger-based vehicles, the gas gauge not working correctly. My 87 acts screwy... I've actually only had to put half a tank of gas in to top it off from 1/4 tank... these things have 23 gallon tanks....
Anyhow, you will need a wiring diagram for your truck (autozone online repair guides, chilton's or haynes) and a meter to check things out. Sometimes the connector on top of the tank goes south due to corrosion, dirt, water, you name it. Hope this points you somewhere in the right direction.
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #3 (permalink)
Old 06-23-2009, 09:58 AM
alright thanks. im thinking of buying it today so ill try that. the other gauges work so i guess ill have to drop the tank.
  #4 (permalink)
Old 06-25-2009, 12:45 AM
wtrueman wtrueman is offline
wtrueman is starting off with a positive reputation.
Gas Tank sending unit
Hi Kernal: Newbi here. I think I have what you said. The tanks empty, or so it says. I run forever on nothing! Now, what you suggested, there MIGHT be a problem under the dash. My temperature gauge does NOT warm up even in the summer and 90's. Any suggestions, Wayne.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
