f250 auto slams into gear - Ford Truck Enthusiasts Forums
Old 12-30-2001, 02:48 PM
shiffer shiffer is offline
shiffer is starting off with a positive reputation.
does anyone know if this is a electrical problem or a transmition problem? speedomiter does not work/ trans slams/ until it warms up, then it works fine. F250 4x4 auto(heavy 250). THANKS,DAN
Old 01-03-2002, 10:02 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
It's probably the vehicle speed sensor. It's located on top of the rear differential.
When the sensor isn't working right the speedometer doesn't work and the computer doesn't know how fast the truck is going, either. It needs to know this to know when and how to shift the transmission.
A new sensor is well under $20. I recommend changing it. It's an easy 5 minute job. There is one electrical connector and one bolt.
Mark
Old 01-04-2002, 02:56 AM
ludis ludis is offline
ludis is starting off with a positive reputation.
Do you need to slam your doors to close? jep 1987 - 1996 F150 & Larger F-Series Trucks 22 02-18-2017 09:34 PM
Slamming between 1st and 2nd gear. imsorope 1987 - 1996 F150 & Larger F-Series Trucks 1 10-23-2016 10:44 PM
E4OD PROBLEMS NEED ADVICE. 94OBS351W 1987 - 1996 F150 & Larger F-Series Trucks 6 06-10-2016 10:18 AM
2003 ford e250 transmission shifting slamming F-WhiteThunder 1968-2013 Full Size Vans 1 05-18-2015 02:59 PM
E4od problem... HELP!!?? plowboycowboy Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 03-29-2015 01:09 PM
Tags
automatic, f150, ford, gear, slams, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
