E4OD locks up
Old 01-02-2002, 10:27 PM
redneckdieselmechanic's Avatar
redneckdieselmechanic is offline
E4OD locks up
Old 01-04-2002, 09:27 AM
NascarNHIS's Avatar
NascarNHIS
NascarNHIS is offline
E4OD locks up
1993 clubwagon - 6 cyl 300ci - E4OD
165,000 miles
for the last year or so
When I put the transmission into REVERSE the engine sometimes will suddenly stall, like the transmission locked up, one CLUNK and it is dead. Restart the vehicle and try again sometimes ok OR restart and power brake (hold down the brake at above normal idle = o.k.).
I also noticed at highway speed the engine seemed to run rough, but it really is the transmission causing a slight bucking feel.
Now the weather has gotten colder, and the truck has gotten older and the problem is getting worse. It stalls much more often.
It now also stutters a bit at local speeds and sometimes stalls at stoplights with the sudden CLUNK, just like the transmission locked up again. (I describe the transmission as locking because when it stalls the engine imediatly stops the van just STOPS, it dose not try to move forward or reveres, it’s not like its in too high a gear and trying to move, it just STOPS with the one CLUNK)
any ideas ?
just a tourque converter or do I need a new transsmision ?
At the price of a new E4OD, it may be new truck
Old 01-04-2002, 09:52 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
E4OD locks up
The problem is that the torque converter is locking when it shouldn't be locked. It feels just like a manual transmission when you come to a stop and forget to push the clutch pedal, right?
The cause can be several things. Low transmission fluid can cause this. A sticking valve in the valve body, a worn out pump, a bad solenoid, an intermittent short in the wiring to the solenoid, and probably a few other things I haven't thought of.
Mark
bradphx
67
01-10-2024 06:12 PM
03-09-2016 12:40 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
02-20-2014 06:51 PM
Quick Reply: E4OD locks up
