You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I had a brake failure in my 78 f250 4x4 camper special. I fixed the problem, but the brake light in the dash is still on. How do I make it go out!? Wondering if this is the reason my brakes are not as powerful as they should be, or if I still have something to work out?
you need to reset the dual master cylinder spool to the center. it shifted to the side that lost brakes to shut them off so you don't lose the other side. best to read the repair manual to do it right. If you are going to own an old truck buy the Ford factory manuals, cd or paper. I payed $15 for the complete set for my '76. get the wiring diagrams too, your life will be soooo much easier
Agreed, they can often be found on ebay for pretty cheap, i paid $25 for my 5 volume set, worth every penny.
I tried to use the procedure listed in one of my old Chiltons truck manuals. It did not work. I manually reset the spool on the bench. All is well now!
