Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-21-2009, 10:17 PM
JJ98 JJ98 is offline
1998 Ford F-150
JJ98 is starting off with a positive reputation.
vin dosent match engine
hi the othere day i was changeing my ac compreser and noticed that my block said it was a 5.4 but the vin said its a 4.6 and the sticker on the vavle cover said its also a 4.6 so whats the deal
  #2 (permalink)
Old 06-26-2009, 11:05 PM
ExpySport ExpySport is online now
ExpySport is starting off with a positive reputation.
What vehicle? Are you the original owner? Any ideas if the engine was replaced at any time in the vehicle's life?
__________________
Tag
2002 Expedition XLT 4x4 5.4L
Sport Appearance Package
124,000+ miles
  #3 (permalink)
Old 07-02-2009, 04:01 AM
1998 Ford F-150
no iam the second and from what i can tell it mite have been rebuilt onces
not to sure
  #4 (permalink)
Old 07-02-2009, 11:37 AM
2000Ford2000's Avatar
2000Ford2000 2000Ford2000 is offline
2000Ford2000 is starting off with a positive reputation.
Editing what I said as I was wrong.
__________________
2000 E-150 Jayco Conversion (5.4)
1989 E-150 Conversion (5.0)
-previous Fords
1989 E-150 Trans-Aire (5.0)
1988 E-350 26' Jayco RV (7.5)
B.C. (Before Children)
1991 Escort (1.9)
1982 Capri (2.3)
1971 Pinto (2.0)
  #5 (permalink)
Old 07-03-2009, 04:13 PM
1998 Ford F-150
the othere thing is its a f150 2wdrrive the tranny 4r70w the vin says 4.6 the engine sticker says 4.6 but the stuff on the right side says it a 5.4 also the vale covers are 14 bolt count
  #6 (permalink)
Old 07-03-2009, 09:57 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
14bolt means Windsor. 11 Bolt is Romeo.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #7 (permalink)
Old 07-13-2009, 09:25 AM
hcbph hcbph is offline
2007 Ford F-150
My Garage
hcbph is starting off with a positive reputation.
Id
Quote:
Can't help you on this but just to show what can happen, at one time I had a 79 Olds Cutlas with a 260 ci diesel. Cylinders went bad and the short block was replaced under warranty. They put in a 350 ci diesel short block, using as many original parts as possible. I don't know how many pieces interchange between the 4.6 and 5.4 but if there are any casting numbers on the block, heads etc they might give a lead on what you have.
Good luck
Paul
  #8 (permalink)
Old 07-24-2009, 04:53 PM
97ExpGuy 97ExpGuy is offline
97ExpGuy is starting off with a positive reputation.
I thought the only difference in the 4.6/5.4 was the longer piston stroke that gave it the more cubic inches. I'm no expert but I wonder if someone slapped the wrong sticker on at the factory. You never know...
  #9 (permalink)
Old 07-25-2009, 04:04 AM
1998 Ford F-150
well its could happen not to worryed iam going to replace it some time soon the head gasket on the left and right banks leak oil
  #10 (permalink)
Old 07-25-2009, 08:53 PM
rplatt56 rplatt56 is offline
rplatt56 is starting off with a positive reputation.
replacing motor because of head gasket leak? And yes the 5.4 and 4.6 share the same block and other parts. The 5.4 has bigger heads to allow for a longer stroke.
  #11 (permalink)
Old 07-26-2009, 03:42 PM
t lindemann t lindemann is offline
t lindemann is starting off with a positive reputation.
4.6 and 5.4 difference
4.6 and 5.4 share most of the enternal parts. the blocks are not the same, they are the same bore but the 5.4 blocks deck is a little taller cause the 5.4 has more stroke. which puts the intake spacing further apart, which wont allow a 4.6 intake to go on a 5.4. pretty sure cranks and pistons are the same , rods are longer on the 5.4.
  #12 (permalink)
Old 08-03-2009, 03:57 AM
1998 Ford F-150
thanks for the info replacing engine for taping and knocking 256000 on it was a farm truck also leaking from crank sral and oil pan also
Tags
1998 , 46 , block , casting , engine , f150 , ford , lookup , match , matches , matching , motor , number , numbers , replacing , truck , vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
