Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-21-2009, 10:13 PM
todd jo todd jo is offline
todd jo is starting off with a positive reputation.
camper special wiring
I pulled the front tank from my 78. I found A pigtail with a plug in the end of it. It looked like a flat 6 or 7 prong plug. I am wondering if this is part of the camper special option. What does it do?
Thanks, Todd
  #2 (permalink)
Old 06-22-2009, 01:26 AM
Jermafenser Jermafenser is offline
Jermafenser is gaining momentum as a positive member of FTE. Jermafenser is gaining momentum as a positive member of FTE.
Yep. It's the feed for the camper body.
Post a pic just to be sure.
__________________
Chad
1997 F350 XL 4WD, 351W & E40D
1978 F150 Ranger XLT 2WD, 351M & C6
  #3 (permalink)
Old 11-01-2009, 06:53 PM
I am not good enough to post a pic. I finally got around to testing the plug. It is a flat 6 prong plug with a factory plug in it to keep critters out. If you remove the cap you can see 1 male prong and 5 female prongs. starting with the male prong the wires tested out Ground, Right Turn, Left Turn, Taillights, B+, ???.
Does any one have any idea what the last wire is used for. I could not get it to show any voltage with my test light? Also, does any one have any idea if the other end of this plug is available? Lastly, why did they bury this handy gadget in such a inaccessible spot? Must be so every PO prior to me could attempt their own trailer wiring?
Todd
  #4 (permalink)
Old 11-12-2009, 11:06 PM
Any one know how this wiring is supposed to work. Still dont know what the last prong does?
Todd
  #5 (permalink)
Old 11-13-2009, 12:28 AM
DL1221 DL1221 is offline
DL1221 is starting off with a positive reputation.
Quote:
Todd
This connector is there so you could plug into the harness that came with the overhead camper, and have all your lights work correctly. Back in the day you could probably buy the other end of this connector at the parts counter, but I'm sure its long gone by now.
This last pin should be for the backup lights, check it out with your test light.
__________________
Bunch of Ford Trucks, One Bronco, and Some Other Stuff. . .
  #6 (permalink)
Old 11-15-2009, 05:05 PM
sounds good! I will try it out.
Todd
  #7 (permalink)
Old 11-18-2009, 08:35 PM
johaner78 johaner78 is online now
johaner78 is starting off with a positive reputation.
ok so i see in the parts book that there was a trailer wiring kit. Does anybody know how the trailer wiring kit would have worked - i'm not sure I've seen any trailer electrical connections on these old trucks mounted at the rear like what comes on the newer trucks today. Any thoughts on this since it goes along the lines of the 6-7 pin connection that was found up under the truck that was supposedly for the campers?
__________________
1996 F150 4x4, 351, auto, LB, K&N Filtercharger, "Silver Bullet"
1978 F250 CC, sb, 4x4 "in the works"
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
