Emergency Brake stuck ON! - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-21-2009, 05:37 PM
webly webly is offline
webly is starting off with a positive reputation.
I just bought a new-to-me '91 Ford Ranger XLT e wheel drive. In talking with the seller, and with my mechanic who checked it over later, both said "the emergency brake doesn't work". Now that I've gotten it home and after driving it around for awhile, everything works fine, so I thought I'd see if the emergency brake REALLY doesn't work. I parked on a hill, put it in neutral, started to roll and pushed the emergency brake pedal down AND IT STOPPED! Who said the emergency brake doesn't work??!! HA!
So I released the pedal and we still don't move.. it's stuck ON. As with most e-brakes, you can go in reverse better than forward. So my question... is this a cable brake to the rear wheels only that is getting hung up or rusted in a sleeve or something? Can I find the cable where it goes into the rear wheels and PULL or HAMMER on it to break it lose? My old '75 350 rusted this way and we just ended up cutting the cables.
So, what should I do?
Thanks for your help,
Jack
proud (but stupid) owner of another Ford truck
Old 06-21-2009, 06:29 PM
Traxxis's Avatar
Traxxis Traxxis is offline
Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.
The cable is easy to find, just look on the outside of the frame on the driver's side. You can then follow it back to the left rear, then it goes across to the right rear.
My suggestion... pull the rear wheels off and try to pull the drums off. See if they are both stuck, or if it's just one. You can also try tapping the outside of the drum to see if you can knock it loose. Also, follow that cable and see if it seems to be kinked or rusted anywhere.
Old 06-21-2009, 07:10 PM
El_Jefe's Avatar
El_Jefe El_Jefe is offline
El_Jefe is gaining momentum as a positive member of FTE.
Its probably kinked somewhere I had a similar issue with my 91. I jiggled and wiggled and got it free. It needed tightening after that but works great now.
Old 06-21-2009, 10:29 PM
Thanks for the answers. Here's what I did: Yes, the cable is visable and reachable along the drivers side. Right before it reaches the left rear wheel, theres an area where the cable is outside the sleeve with the spring. I woggled it in this area and got it to pop free. Assuming there's rust and stuff inside the sleeve to kink it, I sprayed PB Blaster up the end of the tube. Whether it will eventually free it up permanently remains to be seen. I the meantime, I'll heed the mechanic's words... "the emergency brake doesn't work."
Thanks again,
Jack
Old 06-22-2009, 12:24 AM
michigan66's Avatar
michigan66 michigan66 is offline
michigan66 is gaining momentum as a positive member of FTE.
You can buy replacement cables fairly inexpensively - about $20 for each of the 3 segments. I'd suggest that you find out which cable(s) sticks and replace it. I don't know about you, but I would hate to have my hydraulic brakes fail and not have a backup system.
Emergency Brake Repair FoMoCo13 1973 - 1979 F-100 & Larger F-Series Trucks 6 11-27-2016 07:39 AM
2002 Excursion 4x4 Emergency Brake Problems aero993 Excursion - King of SUVs 1 11-15-2016 10:41 AM
Emergency Brake ZachManXLT 1997 - 2003 F150 2 05-01-2016 02:17 PM
Backing plate gone, can I remove the guts? 03f250superduty5.4 1999 to 2016 Super Duty 18 04-18-2015 04:17 PM
Emerg. brake and ABS lights on. Waff78 1997 - 2003 F150 5 12-31-2008 01:18 PM
Tags
350, 91, brack, brake, brakes, ebrake, emergency, ford, loose, parking, ranger, reverse, stick, stuck, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
