Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-21-2009, 05:20 PM
cornfedp cornfedp is offline
cornfedp is starting off with a positive reputation.
Prognosis for using water
Ok, the 400 in my truck is now doing something else to make me worry. It is using water. I dont know if it is burning it off or what. There is no smoke at all and no leaks. I am down to straight water in it because i gave up on refilling with antifreeze. Any ideas on how much time this old truck has left in her?
__________________
Darin K.
1977 F250 400/4spd 2wd
Nebraska Chapter FTE
"What the he** is an aluminum falcon?!?!" - Papa Palpatine
  #2 (permalink)
Old 06-22-2009, 03:49 PM
maskedman maskedman is offline
maskedman is starting off with a positive reputation.
Engine running hot or losing coolant out the overflow line on radiator?See any compression bubbles or signs of in the coolant?Check each spark plug and see if there is any signs or no carbon or color on tip and insulator.Water/antifreeze makes a great carbon remover.Usually the cylinder that is burning the coolant will look almost new.Let us know what you find.
  #3 (permalink)
Old 06-22-2009, 06:29 PM
Engine stays cool until it runs low on water, I will have to pull the plugs sometime this week, heat index is up to 112 tomorrow so it wont be then. No external signs of puking out of the overflow either. No sign of it in the oil either.
__________________
Darin K.
  #4 (permalink)
Old 06-25-2009, 12:16 AM
Holiver31's Avatar
Holiver31 Holiver31 is online now
Holiver31 is gaining momentum as a positive member of FTE.
Well not having that antifreeze in there still will cause it to overheat, as antifreeze dissipates heat better than straight water and raises boil over temp.
__________________
It's an internet forum, get used to it. It's like having a drunk conversation with every single person in the bar minus the "I love you man". "I've seen far more abnormal and unexplainable things at Wal-Mart than I have out in the deep woods." "My drinking crew has a racing problem, or vice versa..."
  #5 (permalink)
Old 06-25-2009, 05:02 PM
grclark351 grclark351 is offline
grclark351 is starting off with a positive reputation.
could be as simple as bad radiator cap, they don't last forever and sometimes don't show signs of leaking. like Maskedman says, i always look at the plugs.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
