Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-08-2002, 09:21 PM
jthomps3 is starting off with a positive reputation.
4 speed standard /removal installation
Any suggestions for the easiest way to get this in and out so i can fix the rear main seal. The engine is an inline 6. I dont have much automotive experience but I think i can handle it. I was just wondering if they was anything i will have to be especially careful doing with this job anything would be greatly appreciated
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-09-2002, 09:10 PM
flyboy2610's Avatar
flyboy2610 is starting off with a positive reputation.
Use a transmission jack and chain the tranny to the jack! It aint no fun watching the tranny fall off the jack, as a friend of mine will attest to! Just lucky no one got hurt! Loosen the pressure plate bolts one turn at a time, going in a star pattern, and mark the position of the plate relative to the flywheel. If you can unbolt the tranny from the bellhousing to remove it separately that is what I would do. Don't start this job until you have the proper clutch alignment tool. Be careful not to get grease on the clutch or flywheel, and THOROUGHLY clean the flywheel before reistalling the clutch. Do not use compressed air to blow off the clutch parts (they may contain asbestos fibers). Take your time, hurrying causes accidents and mistakes. It's not really that bad to do, it'll probably take you longer to replace the seal.
  #3 (permalink)
Old 01-10-2002, 04:35 PM
evenbogey is starting off with a positive reputation.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
