Code 172 and 334
Code 172 and 334
Hey guys, I just ran a test on my 96 f250 5.8 and I got these codes out. From the book I have, they translate to 172- Ho2S Sensor fault/lean and 334- EGR closed valve voltage high. Is my O2 sensor and EGR junk or is there something else wrong? Any help is appreciated
-Brad
-Brad
I know its a stetch but could this in turn make my truck start hard when its been running? When I go to restart it it cranks forever and finally starts and blows a cloud of black smoke. My question is, if its causing a lean code, will the computer try and correct it causing it to run too rich and not want to start? Like i said, a stretch
Then work the EGR over to get it functioning correctly. Once it is fixed, clear the codes and pull them again. Also, check your timing to see where it is set. Recommended setting is 10 degrees BTDC with the spout connector removed on a warm engine (at operating temperture). When was the last time you did a full tune up of your motor?
CentralMassLandscape
04-20-2014 02:32 PM
kwing
19
11-20-2004 12:29 PM
