Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-21-2009, 08:04 AM
Nathan Plemons Nathan Plemons is offline
1995 Ford F-150
My Garage
Nathan Plemons is starting off with a positive reputation.
Is 10% Ethanol Blend a problem for the carb?
When I bought my truck I got gas at a little gas station in Bristol that didn't say anything at all about their fuel being an ethanol blend and it ran pretty well. I got it to Crossville and had to get gas and I noticed that the truck didn't seem to run as good. I can't really quantify it, it just seemed to have a little bit more of a tip in stumble. I got gas at the Shell station and it even said the fuel contained up to 10% ethanol. Before I left town I found several gas stations and they all said they contian ethanol. In Bowling Green, I know BP does, but several stations still have no ethanol markings at all.
All I can figure is that 10% ethanol is simply going to be a fact of life everywhere soon, but for now it just depends on what region you're in. I also know that there were several outboard motors on the lake in Crossville that were running really badly and this was attributed to the ethanol. This makes me wonder if the 302 in my truck might also be affected. I've never really noticed a problem in my other vehicles, but they're fuel injected and can compensate based on feedback from the O2 sensors and such. I'm thinking that on the carb, some minor retuning might actually be required.
Anybody bumped into this before? Penney for your thought.
  #2 (permalink)
Old 06-21-2009, 08:49 AM
gfw1985's Avatar
gfw1985 gfw1985 is online now
gfw1985 is starting off with a positive reputation.
All gas stations run a winter blend and a summer blend. I find I do need to tweak the tuning a bit after they change over. The real problem is those places in the country where E-85 is the only thing sold. Glad I don't have to deal with that.
  #3 (permalink)
Old 06-21-2009, 08:58 AM
1995 Ford F-150
My Garage
Quote:
You and me both! I did a little looking after I posted this and found that TN is required to label anything sold with more than 1.5% Ethanol, where KY is not. I may get the same lousy gas in KY, but they just aren't required to label it.
  #4 (permalink)
Old 06-22-2009, 12:52 PM
Raxid's Avatar
Raxid Raxid is offline
Raxid is starting off with a positive reputation.
We have E85 at most stations here in Minnesota. All our gas has 10% ethanol. Sometimes you can find some that doesn't have any ethanol but its marked for off-road use only and then they change an extra .10 for running it.
  #5 (permalink)
Old 06-23-2009, 01:26 AM
Dirt racer's Avatar
Dirt racer Dirt racer is offline
Dirt racer is starting off with a positive reputation.
I live in mn too. I only put about 12k on my 429 in my 75 truck and had to rebuild my carb, and replace my holley fuel pump. Both were new on the rebuild. I am not sure but seems to be hard on the gaskets.
  #6 (permalink)
Old 06-26-2009, 09:02 PM
dinosaurfan dinosaurfan is offline
dinosaurfan is gaining momentum as a positive member of FTE.
Smile I wouldn't worry about it
10% ethanol has been in most of our fuel where I live for years. It just doesn't cause nearly the problems some folks imagine. There ARE lots of people who are more than happy to take your money and fix the problem your truck may realy have, however. Lets think about this....if your fuel has 10% ethanol, and ethanol has 2/3rds the BTUs of gasoline, your new 10% blend has about 97% the BTUs of the ethanol free fuel you used to have. Is your carb set SO lean it can't deal with a 3% reduction ? Most vehicles new to ethanol in the fuel just need a new fuel filter, and some need the carb cleaned out. Ethanol IS a very good solvent, and any trash in the fuel system will get loosened up and floated into the filter and the float bowls.
DinosaurFan
  #7 (permalink)
Old 06-27-2009, 08:43 AM
1995 Ford F-150
My Garage
Quote:
DinosaurFan
You're very likely correct. All of the driveability problems that I noticed after getting ethanol fuel continued and got worse after I got back home. Now where I've got gas in town is not labeled as an ethanol blend, but it turns out they they're not required to label it in KY! So who knows, it could be the same stuff. I took my carb apart and found a bunch of rust and other crud. I took the whole thing apart and cleaned it real good. I replaced the fuel filter as well. Now the truck is running awesome.
Now I would not be surprised if I have some more troubles with the rubber fuel line components at some point, but the truck is 35 years old anyway, they're due to be replaced.
  #8 (permalink)
Old 06-27-2009, 11:49 AM
gearhed1971's Avatar
gearhed1971 gearhed1971 is offline
1973 Ford F-100
gearhed1971 is starting off with a positive reputation.
After talking to a guy who lost a mach mustang to a rubber fuel line leak,I'd use ALL steel lines.
__________________
gearhed1971
1973 f100-390 4wd
1963 falcon-under construction
1951chebby special deluxe(for sale)-SOLD!!!
daily beater poontang sunfire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
