Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-21-2009, 01:33 AM
whatthencuz's Avatar
whatthencuz whatthencuz is offline
whatthencuz is starting off with a positive reputation.
Truck running hot
I have a 82 wit a 302 c6 and it keeps running hot. There was no thermostat when I checked it, changed the water pump, and the fan is direct. There is no fan clutch, I have a flex blade fan. Also the temp sensor is new. I dont know what else it could be. The radiator isn't leaking and all the hoses are semi new. What do u guys think it could be? Any input is appreciated
PS the radiator cap is kinda old, doesnt look old; there is no white smoke coming out of my exhaust so i dont think it could be a head gasket
  #2 (permalink)
Old 06-21-2009, 02:12 AM
Jmeyer1990's Avatar
Jmeyer1990 Jmeyer1990 is online now
Jmeyer1990 is gaining momentum as a positive member of FTE.
air in the system?
I had the same exact thing happen to me with my Topaz (yes i know, its not a 302 82 f series), but none the less, after I replaced my water pump, i managed to get an air bubble, which made my car overheat within just minutes of driving.
purge the system!
__________________
-Josh
Nebraska Chapter Member
... but i kept losing service in Victoria's Sectret, so I gave up.
  #3 (permalink)
Old 06-21-2009, 02:55 AM
i turned the truck on to get the water flowin and make sure all the air was out but even before i changed the water pump and installed a thermostat it had no air in the system and it still got hot. It doesnt get hot right away it takes quite a few minutes to get hot
  #4 (permalink)
Old 06-21-2009, 03:05 AM
PS the radiator cap is kinda old, doesnt look bad tho
  #5 (permalink)
Old 06-21-2009, 08:51 AM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a good reputation on FTE. ctubutis has a good reputation on FTE.
Are you relying on a factory gauge to tell you it's hot? I would verify it with a 3rd party
gauge, factory gauges are subject to various electrical issues that cause false readings.
  #6 (permalink)
Old 06-21-2009, 10:04 AM
WAExplorer WAExplorer is offline
WAExplorer is starting off with a positive reputation.
The cap can cause it to overheat/run hot if it's bad or weak. If you can't test, it replace it. It's cheap enough. Or the radiator could be plugged up.
  #7 (permalink)
Old 06-21-2009, 10:27 AM
6fifty_f1fifty 6fifty_f1fifty is offline
6fifty_f1fifty is starting off with a positive reputation.
The only other thing I can think of is if it has the right water pump, the ones with individual belts are different from the ones with serpentine belts (serpentines) have reverse impellers because they rotate the opposite way... just a thought.
__________________
Robert
--1980 F-150 Custom 302, 4sp
--1980 F-100 Ranger 300, 4sp
--1988 E-350 Motorhome 460, C-6
--2006 VW Golf 2.0L, with a POS 4sp automatic...
Whidbey Island, WA
  #8 (permalink)
Old 06-21-2009, 04:21 PM
bought a new radiator cap and it's still getting hot. when i have the truck running and the cap off i can see the water flowing but i think im just gonna replace the radiator since it ain't that much.
the new water pump looked exactly like the one it had (it still had the original ford one)
  #9 (permalink)
Old 06-21-2009, 05:21 PM
Let us know if the new radiator fixes it
  #10 (permalink)
Old 06-21-2009, 05:58 PM
ArdWrknTrk's Avatar
ArdWrknTrk ArdWrknTrk is offline
<--Dog is my Co-pilot
ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold
Does your lower radiator hose have a spring in it to keep it from being sucked shut by the water pump?
__________________
Jim
'87 F-250 4V 460, T19, 4x4, 4.10 sterling 10.25" - Lil' Red
http://i246.photobucket.com/albums/gg117/donjamer/FTE%20Pics/blumax500-1-1.jpgFTE Fraternity of Blue Max
  #11 (permalink)
Old 06-26-2009, 02:37 PM
ok i did a flush and replaced the radiator and the needle on the gauge is under the "A" in "NORMAL" when im driving. When I park for a couple of minutes and turn it back on the needle is is past the "H" but as soon as I start driving again it goes under the "A". Is that normal? I put a 180 degree thermostat in.
and the lower hose does not have a spring
  #12 (permalink)
Old 06-26-2009, 03:04 PM
ArdWrknTrk's Avatar
Yes, it's normal for it to be higher with the engine off. (there's no coolant circulating)
But mine rarely goes past "r".
Get a spring or you will suck the hose shut at higher rpm's
__________________
Jim
  #13 (permalink)
Old 06-26-2009, 03:46 PM
jsutton's Avatar
jsutton jsutton is offline
1977 Ford F-100
My Garage
jsutton is starting off with a positive reputation.
I agree with ctubutis an aftermarket gauge would tell you exactly what temp your running at. And also get a lower hose with the spring in it.
__________________
'77 F100 302 C4 John Deere Blitz Black and Cragar Soft 8s
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=202355&.jpg
  #14 (permalink)
Old 06-26-2009, 05:45 PM
dave2180's Avatar
dave2180 dave2180 is offline
dave2180 is starting off with a positive reputation.
my truck, 1980 f150 351c c6, runs hot when i cut it off too; but when i cut it back on it goes to normal. so yea its officially normal.
  #15 (permalink)
Old 07-04-2009, 02:21 AM
well i ran it for a good while and the gauge is still under the "A" and sometimes it would go past the "H" but one night my lights started flickering and when I went to check under the hood, a cable from the alternator was loose. After tightening it and running the truck some more, the gauge wouldnt pass the "H" anymore
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
