Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-04-2009, 02:21 AM
whatthencuz's Avatar
whatthencuz whatthencuz is offline
whatthencuz is starting off with a positive reputation.
PS thanks for all the input
  #17 (permalink)
Old 07-04-2009, 06:30 AM
ArdWrknTrk's Avatar
ArdWrknTrk ArdWrknTrk is online now
<--Dog is my Co-pilot
ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold
The "H" in "normal"??? I have an early '87, does your dash temp gauge have a Hot position?
Check/change your block ground cable.
Sounds to me like there's more than one fault in your charging system.
__________________
Jim
'87 F-250 4V 460, T19, 4x4, 4.10 sterling 10.25" - Lil' Red
http://i246.photobucket.com/albums/gg117/donjamer/FTE%20Pics/blumax500-1-1.jpgFTE Fraternity of Blue Max
  #18 (permalink)
Old 07-04-2009, 10:05 AM
skysoldiervn's Avatar
skysoldiervn skysoldiervn is offline
1984 Ford Bronco
skysoldiervn is starting off with a positive reputation.
Thumbs up Running Hot
My 84 had a problem with gauges reading higher than normal. Sometimes they would read ok, the next time I would be overheating by the gauge and full of fuel. I knew these were not correct readings. I checked all grounds and it turned out to be the dash voltage regulator. This might be the problem.
  #19 (permalink)
Old 07-04-2009, 10:31 AM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a good reputation on FTE. ctubutis has a good reputation on FTE.
Quote:
This is exactly one of the reasons why I suggested long ago to not rely on what
factory gauges are telling you....
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
