It depends on brand and capacity. I have a 12ton Harbor Freight H-style press, and it's not bad. Great for wheel bearings, and other small jobs. At work we have a giant A-frame that has a bender attachment, it could fold a 4' sheet of 1" steel in half.
What models are you looking at?
__________________
Jared
The government said all my vehicle were too old to be clunkers
I have a 10 ton press from Harbor Frieght. i can't ell you what the pros and cons are. But I can tell you, that unless your floor is level, it will rack itself. My shop floor was just wood planks, and the first time i used it, it racked way out of shape. so I had to take it all apart and put it together straight again, then I welded all the joints, so it won't happen again.
I also had to replace the jack after only a short time. Harbor Frieght jacks are just crap. I wrote about that in another post in this section.
__________________
92 F-150 flairside all stock 5.0 auto 2WD
93 F-250 4x4 flatbed 5.8 auto KnN, throttle body spacer, underdrive pulleys, flowmaster
73 Jeep CJ5 springover axles, reversed front shackles, 304, T-18, lockers front/rear, 4:29 gears, 33s
87 Toyota Tercel Tuner some engine mods exhaust
I'm not a press expert but what does the floor have to do with? Its pushing against itself isn't it? I can understand the importance of it being square with its self I also had planed on welding mine as well once everything checked out.
Check the club. There are photos.
Oh- you mean in the context of hydraulic presses? In that case, I do not know the answer, but supect he is referring to twisting or otherwise working itself out of square.
__________________
Kal
97 250 PSD Ex Cab Sd 4X4 ZF5 155k
Buncha low budget mods
"I tried being reasonable. I didn't like it."
I second the flat floor and I wouldn't get the A-frame press. With an H-frame you have the option of moving the ram sideways to accomodate unusual sized parts. With the A-frame you can only press in the center of the rails.
__________________
2002 F350 7.3 Ltr. 6sp.DRW 170K miles, 13' service body W/2200 # Venco hoist, Air compressor,10KW welder/generator, Air Horns, ceiling mtd CB W/250W Amp, Exhaust brake, Aux. Idle Control and Vac. operated hot water control.
1952 F1 flathead Project Truck
(It's got eight cylinders and I use them all )
Might I suggest check Craig's list, happened to come across a quality 20T H frame shop press off Craig's list and got a great deal, not only for the press but it also included several press plates. Eventually installed heavy duty wheels.
__________________
'problem with engaging in useless activity is never knowing when your done'
