Reverse rotation front axle. - Ford Truck Enthusiasts Forums
Old 01-16-2002, 08:20 AM
slowsix slowsix is offline
slowsix is starting off with a positive reputation.
Old 01-16-2002, 09:16 AM
4x4E350 4x4E350 is offline
4x4E350 is starting off with a positive reputation.
I have installed a front 2 1/2 ton military axle on my truck, and after hooking everything up found out that it's a reverse rotation axle. Which means, the front drive shaft needs to turn in the opposite direction of the rear. Most vehicles(that I know of) have the rear and front turning in the same counter rotation.
Has anyone heard of a vehicle that had this reverse rotation front axle and transfer case?
Ford used reverse cut Dana front axles, when they flipped them upside down, they put a reverse cut ring & pinion in them, so they weren't reverse rotation. But they dont make reverse cut ring & pinions for the axle I have.
Old 01-16-2002, 09:25 AM
Ford79's Avatar
Ford79 Ford79 is offline
Ford79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to behold
Is the axle a drop out carrier type or a top loader?
Old 01-16-2002, 09:40 AM
It's a drop out carrier type. I think I know were your going with this, rotating the carrier 180 degree's. The only problem with that is, my steering linkage would interfere with the carrier and pinion then. Unless there is a way to avoid that, I havent figured it out yet.
Old 01-16-2002, 09:55 AM
Ford79's Avatar
I've got the same axle in my mud truck. Instead of flipping the carrier, we flipped the whole front axle. This put the diff on the driver side(so I could use a ford case) and made the diff rotade the right way. I'll try to get some pics of a couple of our trucks front ends and post them so you can see how we made them work.
Old 01-16-2002, 10:04 AM
Ford 79,
I was just looking in your Gallery of pictures, and saw your mud truck, you have the same axle as I do. That's a great idea, did you just keep the steering linkage above the carrier? And did that work ok without any interference? How did you make a spring pad by the carrier?
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
Exhaust (cat) 1987 - 1996 F150 & Larger F-Series Trucks 7 08-22-2012 11:39 PM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 10:21 PM
Tags
1978, 2001, axle, case, cut, f250, f350, ford, forum, front, linkage, reverse, reversing, rotation, transfer, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
