Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-20-2009, 08:58 PM
KaoticCreations's Avatar
KaoticCreations KaoticCreations is offline
KaoticCreations is starting off with a positive reputation.
spittin and sputterin
Well now my 87 ranger with a 2.9 wont stay running after warming up to operating temperature. The truck starts runnin as if it were runnin out of gas and then often times stalls out especially after letting off the accelerator. What do ya think boys and girls?
Thanks
  #2 (permalink)
Old 06-20-2009, 09:57 PM
87 XLT 87 XLT is online now
87 XLT is gaining momentum as a positive member of FTE.
Take about 20 minutes to:
Pull the codes
Check fuel pressure
Test with a vacuum gauge.
One of these very simple tests should give you an idea of whats wrong.
Heres a interesting link
http:On Fire
  #3 (permalink)
Old 06-21-2009, 04:19 AM
El_Jefe's Avatar
El_Jefe El_Jefe is offline
¿Qúe onda amigo?
El_Jefe is gaining momentum as a positive member of FTE.
Sounds like a fuel problem...check your fuel filter
__________________
1991 Ranger Custom 2.9L V6, Gas/Air Hybrid, 6"Lift w/ 33s
  #4 (permalink)
Old 06-21-2009, 08:35 AM
lowdownndirty lowdownndirty is offline
lowdownndirty is starting off with a positive reputation.
after it warms up....that when the truck gos in to open loop,
pull codes
check out your map,TFI and o2 and tps..the TFi is known to go out in these trucks,
but pull codes and let us know what codes you come up with
fordfuelinjection.com
  #5 (permalink)
Old 06-21-2009, 02:00 PM
Just put on a brand new fuel filter about two days ago, my truck ran much better, but I knew that wouldn't cause this to happen only after it has warmed up so I wasn't surprised when it spat at me again. But your exactly right lowdownndirty, It has to be something to do with the ecm going into open loop after hitting operating temp. But I haven't heard those words in years...not since EMS class at Wyotech..hahaha, the good old days. Anyways, thanks bud, that idea has been lingering around in the back of my head with all my other thoughts that I can't remember (had too much fun growin up). I'll start by seeing if I can pull some codes. My check engine light isn't on, but who knows maybe the MIL is broken too. Darn thing is just fallin apart, it's a sad sight...
  #6 (permalink)
Old 06-21-2009, 02:41 PM
88 is the 1st year of Ranger thaat was equipped with a check engine light. The 87 does'nt have one which is why it's even more important to check for trouble codes on an 87.
About 3 months ago my 87 2.9 was bogging down at 80 MPH, first thought was a clogged fuel filter, but it was only 6 months old. Next thought was maybe a bad intank fuel pump, but no change when I switched to the other tank. So that was'nt it either.
When I got home I pulled the codes "system pass" , no help there.
Checked fuel pressure no problem there.
Put the vacuum gauge on it & checked for a clogged cat no problem there either. Go figure that, theres nothing wrong so why was it bogging at 80 MPH?
I might never know since it's been running perfect ever since I did the tests??????
BTW, open loop is when the engine is cold & closed loop happens when engine temp gets to about 140 degrees.
Like lowdowndirty mentioned a bad MAP could cause you symptoms.
I would'nt be surprised if you pulled a code 22 "MAP sensor whacked" Thats a technical term.
  #7 (permalink)
Old 06-21-2009, 07:29 PM
El_Jefe's Avatar
¿Qúe onda amigo?
Talking
Quote:
whacked
Main Entry: whack Pronunciation: \ˈhwak, ˈwak\ verb
Etymology: Probably imitative of the sound of a blow
transitive verb to strike with a smart or resounding blow
__________________
  #8 (permalink)
Old 06-21-2009, 10:59 PM
I suppose that would explain why Ive never seen my check engine light come on at any point in time...hahaha and I'm about ready to "whack" this truck at this point.
  #9 (permalink)
Old 06-22-2009, 02:00 AM
Quote:
Originally Posted by El_Jefe View Post
whacked
So technically speaking "whacked " is not really a technical term at all LOL.
  #10 (permalink)
Old 06-22-2009, 02:37 AM
Quote:
Well, you might want to "whack" your truck after you figure out whats wrong with it, but it's probably some simple little problem like a bad sensor.
I've had my 87 since it was new & it has 240,000 miles on it. It just keeps going & going & going.
Great little truck.
  #11 (permalink)
Old 06-22-2009, 04:50 AM
El_Jefe's Avatar
¿Qúe onda amigo?
__________________
  #12 (permalink)
Old 06-23-2009, 05:55 AM
kaotic, if we could only rember all the things we learn, when we are in need of them hahaha...
  #13 (permalink)
Old 06-25-2009, 07:00 PM
well pulled the codes...4 of them, but not a big deal. 67,Neutral safety switch, which hasnt worked since I bought it anyways, and not very worried about it. But also a 32 -egr not controlling, and an 83- egr control circuit failure, I wasn't too surprised. and a 91- air/fuel mix not within self test range. So I'm thinkin the DPFE sensor definitly needs replaced, and I'm thinkin probably the valve as well...
  #14 (permalink)
Old 06-26-2009, 01:23 AM
Looks like the EGR valve is stuck open & thats causing your 91 lean code. Thats also why it wont idle, it's too lean.
Take a look in your Haynes for how to test the EGR.
  #15 (permalink)
Old 06-26-2009, 03:12 PM
I got a chilton for this vehicle, and a haynes for full size fords of the same years and I've read through both of them about the egr, pretty simple stuff, just never messed with one before. But I just picked up an egr valve and it's dpfe sensor at the scrap yard....only 20 bucks so I figure just try em, what's the worst that can happen... but right now I'm takin a break from tryin to loosten that f'in exhaust line off the "new" valve. old rusted crap... oh well, you'll have that
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
