Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-20-2009, 08:27 PM
firepop5 firepop5 is offline
firepop5 is starting off with a positive reputation.
A/C pressures
91 E150 4.9L V6 with dealer installed A/C
Converted from R12 to R134A several years ago. System has low pressure port at receiver drier but no high pressure port. Every year I add a can of R134A and system works fine for a year. I finally got a set of gauges to check system pressure. Does anyone know what the following pressures should be:
1) Pressure at low port with engine running and a/c off
2) Pressure at low port with engine running, a/c on and compressor engaged
3) Pressure at low port with engine running, a/c on at moment compressor cycles off.
Thanks
  #2 (permalink)
Old 06-21-2009, 01:52 PM
subford's Avatar
subford subford is offline
subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE.
1) Pressure at low port with engine running and a/c off:
Ambiant Air Temp.(F) Low Side Pressure(psi)
50- 45
55- 51
60- 57
65- 64
70- 71
75- 78
80- 86
85- 95
90- 104
95- 114
2) Pressure at low port with engine running, a/c on and compressor engaged:
40-45
3) Pressure at low port with engine running, a/c on at moment compressor cycles off:
Should not happen but the Low side cutout switch should be set to open (stop the compressor) at 24 PSI and will let the compressor restart at 43.5 PSI.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #3 (permalink)
Old 06-21-2009, 02:27 PM
Thanks subford
For #1, left column is temp and right column is psi, is that right.
  #4 (permalink)
Old 06-21-2009, 03:17 PM
subford's Avatar
Quote:
Originally Posted by firepop5 View Post
Thanks subford
Yes that is right.
__________________
subford@gmail.com
  #5 (permalink)
Old 06-21-2009, 03:47 PM
Compressor was cycling off as you said, as pressure dropped to about
24 PSI and turned on again when pressure built up. Added one more can of 134A and nice cool air constantly. Thanks again
Tags
06 , 2001 , 95 , ac , compressor , cycle , e350 , f150 , ford , high , low , port , pressure , pressures , service , side
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
