SAE #1 & SAE #2 clutch housings
Can anyone tell me if the 370 & 429 engines used the (I beleive it is called) SAE #2 clutch housing? (I think the SAE #1 is a light/conventional bellhousing like a NP 435 would bolt up to). The SAE #2 if I understand correctly is an adapter that bolts to the block
and has a large circle with many bolt holes, that bolts to the transmission 1/2 of the clutch housing. Thanks, Bob
[updated:LAST EDITED ON 12-Jan-02 AT 11:36 PM (EST)]SAE housing bolt patterns are perfectly round.
SAE#1 is typical of a bigger diesel, like an 8V71 or 350 Cummins. If I remember right, SAE #1 has a 20-7/8" bolt circle.
SAE#2 is similar, but not quite as large.
The higher the SAE number, the smaller it gets. A SAE#6 is only about 8" in diameter. I can dig up the exact SAE specs if you need them - I have all of the dimensions at work.
I think the 370 and 429 engine blocks used a big-block pattern, but I am not sure. I never wrenched on one. If there's two top corners to the pattern like on a 460, it's definately not SAE.
It is possible that the factory used an adapter to adapt the engine block to a SAE pattern, allowing use of a different transmission. These adapters are quite common on industrial-ized automotive engines.
Automotive engines have the clutch inside the bellhousing, where industrial/marine/big truck applications have the clutch (if one is used) and flywheel inside the flywheel housing, and a nearly flat adapter plate behind it all connecting the transmission to the engine.
Clear as mud, right???
Art
Art
Thanks for the reply. Yes, I understand completely. I'll check the front of my Fuller 6sp Monday, and get the circle diameter. The 370,429 & 460 are all suppose to have the same block from all I can learn. Now I need to find out if they put an SAE clutch housing on either the 370 or 429. I am trying to get more gears behind my 460 for towing. Thanks, Bob :-)
FuzzFace2
73
11-06-2023 05:32 PM
Jolly Roger Joe
32
08-06-2016 02:40 PM
melvinew2
07-19-2016 10:12 AM
