22 gal. tank. It's tight but it fits and doesn't rub anywhere. Nuts are welded into the inside of the square tubing. All mounting nuts are welded to truck frame for easy installation. Fuel tank is mounted above lower frame lip instead of below like all of the others that I have seen.
__________________
Bobby
1972 F100 Short Bed
1963 Uni Longbed 390/C6
1967 Mustang Fastback 390 4-speed
That looks slick. What year mustang did that come from and where did you pick that new on up from? I think that is the answer to my problem.
It's a 1970 Mustang, 22 gallon, non-emission fuel tank. Picked it up off of EvilBay. It's the Canadian made tank, not Taiwan, Chinese, etc. Comes with sending unit. I mounted it on a 1" square tube frame and then cut the rivets and removed the far-most rear crossmember and slid it in on top of the lower lip of the truck frame. This way it gives you more clearance under the tank. With the bed installed there is about 1/8" clearance between the tank and the square cross section of the bed, where the bed contacts the truck frame.
To clearance the underside contour of the rear-most part of the bed the removed truck crossmember must be slightly modified and re-installed upside down. I welded mounting nuts to the inside of the rear crossmember for easy installation because it's a PITA to get your hand and a wrench up inside the frame to bolt the crossmember back in. I will be finishing the tank install this weekend. I have a real sano idea for the fuel door in the rear of the bed.
__________________
Bobby
1972 F100 Short Bed
Do you remember the EvilBay-user-name ya scored that tank from???...
I've been lookin' for somethin' for my '56 Effie and cant decide between the Mustang and he Bronco tanks......
Sort of the same units...just lookin' for a good deal......
__________________ Gimme Fuel...Gimme Fire...Gimme that which I desire...
Vintage '63-64 Buddy Barr/Holley Triple-Duce...
TOTAL cfm = 730
Now I just need to finish my motor...duh...
The guys ebay name is rstanggang. No problems, fast shipping, tank came with sending unit, filler hose, etc. They are out of Kentucky. I believe their business is called Kentucky Mustang Parts. I paid $119 + shipping.
__________________
Bobby
1972 F100 Short Bed
is that a long bed or short and how do you bolt the box on there is two bolts that use the rear crossmember to bolt thru from under the bed that are not accessable from the top inside of bed and can you show the front area where the fuel line and float assy is (view). Very nice set up kinda curious as to the filler hole setup is going to be done.
__________________
390428cjt
FORD IS THE MOUNTAIN THE ROCK FELL OFF OF
1972 F-250 Camper Special 396 FE,C-6, Dana 60 4.10 limited slip.
1996 F-150 XLT 4X4 5.8 Heavy Duty Package
1982 escort 49k original miles 2dr hatch
The truck is a short bed.
As to your question about the rear bed bolts, the crossmember that used to run between the rear leaf spring mounts is now relocated all the way to the rear of the frame. It has been slightly modified and is installed upside-down to accomodate the contour of the underside of the rear of the bed.
The nuts that bolt down the rear of the bed are welded inside the crossmember because there is no room to get a wrench inside the frame...
The nuts that mount the crossmember are also welded to the inside of the crossmember...
The rear bolt hole is for the rear bed mounting bolts...
I have not finished the fuel line plumbing or the sending unit wiring. The sending unit is on the front of the tank behind the diff...
__________________
Bobby
1972 F100 Short Bed
nice one more question,, how is the bumper brackets going to be bolted on as there doesnt seem to be enough room to get at the brackets bolts to the frame?
__________________
390428cjt
that is what a weld in roll pan is for.....atlest that is what i would do.
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
Thinking the Government stimulus plan is working is like thinking that taking water form the deep end of a pool and dumping it in the shallow end will raise the water level of the pool.
SoCal FTE Member
Nuts will be welded to the inside of the frame rails so all of the bolts will go in from the outside. There is enough room, the bolts just can't be too long.
__________________
Bobby
1972 F100 Short Bed
Man...that install came out sweet! Thanks for the info...
Now I got some more options...
TOTAL cfm = 730
Sorry but a roll pan doesnt look right on any antique truck!! Chrome is where its at on an old truck and lots of it.
__________________
390428cjt
