Need To Order New Engine Tonight! Help!
I need to order a new engine for my 1969 F100 tonight. My truck has a 302 in it. Trans is manual 3 speed. I would love to just be able to take out the old engine and put in the new. Are there better solutions than getting another 302, or is that the most simple thing to do? I have a contact who can buy Fords crate engine straight from Ford. Or, what about this one from Jegs:
https://www.jegs.com/i/ATK-Engines/059/HP79C/10002/-1
Or this one from Speedway Motors:
https://www.speedwaymotors.com/BlueP...02,297641.html
Thanks in advance for your responses!
Impossible!
Impossible!
All parts and new vehicles have to be purchased from authorized FoMoCo dealers.
However, since I made this post, I called him to see what was available. Turns out what he can get is rebuilt Boss 302 engines.
So....back to my question.....
Anyone have any suggestions about an engine?
on
If I was gonna buy a 302 crate engine, I'd buy this one.
https://www.summitracing.com/parts/m...14ct/make/ford
All of those are pretty expensive for what they are. ATK has a shortblock in the $1200 range. Get one of those, some blueprint aluminum heads for $1000, budget dual plane intake like summit or weiand, comp XE cam and have way more bang for your buck.
If you have a 302 already swap over the tins and hardware to save money.
The big problem you'll find with any "later model" 302(pushrod motor) is the block is NOT machined for the pivot ball for the clutch linkage. Into the later 80's or so, the mechanical linkage went away for hydraulic clutch control. Thus the boss and threaded hole was removed from the block casting.
Definitely something to check on if you order a motor from someone.
In 1984, the mechanical linkage went away for hydraulic clutch control. Thus the boss and threaded hole was removed from the block casting.
I'm sure I will notice a huge difference. I just found out yesterday that two cylinders were not firing at all. Checked plugs, plug wires, distributor....and no change. Pulling off the plug wires from those two cylinders made no difference at all in the way the engine ran. Pulled off the valve covers and they had moisture in them :-(
