Mustang Fuel Tank Install - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 02-14-2012, 05:16 PM
instig8r63 instig8r63 is offline
instig8r63 is gaining momentum as a positive member of FTE.instig8r63 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by DLP Performance View Post
I like this idea! Do you have any new pics of the finished product?
The fuel tank install is finished but the truck is still a project in the works. I've since lowered the truck, mini-tubbed the bed and installed a 460/C6 combo.
  #32
Old 05-04-2013, 04:52 PM
Fastbull Fastbull is offline
Fastbull is starting off with a positive reputation.
I'm doing a similar setup on my '67 after reading this and was wondering if you had any pictures of the fuel fill under the fuel door. This is the last thing I have to do to be finished and am having trouble figuring out how to set it up with so little room between the tank and the bed floor. Any advice would be greatly appreciated. Thankyou
-Matt
  #33
Old 05-04-2013, 05:32 PM
Quote:
-Matt
If you have a vented cap, just use your filler neck, hose and vented cap from the stock in-cab tank.
  #34
Old 05-05-2013, 10:10 PM
Perfect thankyou. I originaly wanted to use a marine style cap and filler but the one I needed was $200 so I'll do this instead. Also does anyone know if the caps listed for the stock tank in lmc catalog are vented? Thankyou
-Matt
  #35
Old 05-06-2013, 08:35 AM
The caps should be listed as w/vented tank and w/o vented tank. Vented tank will have a non-vented cap and vice-versa.
  #36
Old 06-19-2013, 02:21 PM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is offline
MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.
SWBO just gave me the green light to do this , she's tired of smelling gas in the truck .
Woo hoo ! tank is ordered , I am going to move my filler from center to the drivers side rear corner .
  #37
Old 06-20-2013, 10:07 AM
Area351's Avatar
Area351 Area351 is offline
Area351 is starting off with a positive reputation.
Ok, this question has come up several times and after some research I think I have found a solution to installing a Mustang tank that will work on a fuel injected engine like I am planning.
1964-68 Ford Mustang Fuel Injection Tank
This tank has provisions for not only an in-tank fuel pump, but it also has a bung for a myriad of aftermarket sending units with different ohm ratings and the price looks very reasonable.
  #38
Old 06-26-2013, 11:47 AM
Bobby
I have a couple questions
what filler neck /cap did you use ? stock ones ?
if so do you have any issues with gas spilling out on quick take offs ? I know the early mustang always spit gas out the back if you stomped on it .
also did you install any kind of vent system for the tank ?
thanks in advance
mike
  #39
Old 06-26-2013, 12:17 PM
abyars111's Avatar
abyars111 abyars111 is offline
abyars111 is starting off with a positive reputation.
Do you use the Mustand sending unit with these tanks?
  #40
Old 06-26-2013, 04:34 PM
boo-yaa138's Avatar
boo-yaa138 boo-yaa138 is offline
boo-yaa138 has a great reputation on FTE.boo-yaa138 has a great reputation on FTE.boo-yaa138 has a great reputation on FTE.boo-yaa138 has a great reputation on FTE.
Quote:
Yes you use the stock mustang sending unit. it will work with the stock gauge in your truck
  #41
Old 06-26-2013, 06:26 PM
NEVER MIND SEE MY CAP QUESTION ALREADY ANSWERED
  #42
Old 10-31-2014, 03:04 AM
bajafishnut's Avatar
bajafishnut bajafishnut is offline
bajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to behold
Bobby, I must apologize to you, for not giving you the Kudos you deserve, in another thread. But here, you have done what anyone would love to be able to do. You have inspired me to try this. I have a bed off project starting when I get back to Baja, and as usual, projects grow to fill more than the available time & money. Clean, clean, clean, is all I can say... Hope I can do similar work...
Baja
  #43
Old 10-31-2014, 07:58 AM
Quote:
Baja
Thanks buddy. When I started the tank install, I had a basic plan and I just wound up fabbing as I went along.
Take your time and good luck
  #44
Old 10-31-2014, 08:10 AM
ultraranger's Avatar
ultraranger ultraranger is online now
ultraranger is a splendid one to beholdultraranger is a splendid one to beholdultraranger is a splendid one to beholdultraranger is a splendid one to beholdultraranger is a splendid one to beholdultraranger is a splendid one to beholdultraranger is a splendid one to behold
Quote:
There were (3) tanks used in the Mustangs from 1965-1970.
The '65-'68 tank was 16 gallons.
The '69 tank was 20 gallons.
The 1970 tank was 22 gallons.
All three of these tanks had the same bottom half. The upper half is the difference for the added capacity.
The sending unit is 10-75 ohms (10 ohms full, 75 ohms empty). However, the Mustang sending unit is specific to the capacity of the particular tank. --longer travel of the float arm as the tank capacity increases.
A sending unit for a 16 gallon or 20 gallon Mustang tank isn't going to be accurate if used in a 22 gallon tank.
1965 Shelby R model Mustangs came from the factory with 34 gallon baffled gas tanks. This was accomplished by putting the bottoms of TWO gas tanks together.
https://www.google.com/search?ie=UTF...tm%3B650%3B434
  #45
Old 11-01-2014, 02:36 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1970 Mustang (Cougar same) fuel tank with Evaporative Emission is 20 gallons, without Evaporative Emission, it's 22 gallons. Same sending unit used with both.
Evaporative Emission introduced in 1970, was mandatory in sold new CA vehicles, may have been mandatory in other states as well.
C8ZZ-9275-C (replaced C5ZZ-9275-A) .. Fuel Tank Sending Unit: 1965/68 Mustang & 1967/68 Cougar.
C9WY-9275-A .. Fuel Tank Sending Unit: 1969 Mustang/Cougar.
D0WY-9275-A .. Fuel Tank Sending Unit: 1970 Mustang/Cougar.
Volt Meter instig8r63 1967 - 1972 F-100 & Larger F-Series Trucks 30 03-14-2016 07:52 AM
Replaced headlights 4x4EX Expedition & Navigator 4 03-01-2014 09:53 PM
Leather seat repair, no more worn sides 4x4EX Expedition & Navigator 10 12-18-2013 03:10 AM
Tech tip: 1994 Ranger Fuel pump install Midwest Dually Ranger & B-Series 17 10-25-2013 11:33 AM
Super Duty Plow Trucks POST PICS!!! maverick 21 1999 to 2016 Super Duty 27 12-07-2008 06:43 PM
Tags
1955, 1967, 1972, bed, f100, ford, fuel, gas, gauge, installing, large, mustang, sending, tank, truck, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
