Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-20-2009, 04:13 PM
mystic04 mystic04 is offline
mystic04 is starting off with a positive reputation.
horrible lifter tap
i recently purchased a 1998 e150 that had a noise in the top end do to poor maitenence i thought i could fix it easily but now im not so sure after much listening i am pretty sure its a lifter that wont pump up and it taps bad is there a magic potion i can dump in with oil and possibly cure this i have decent mechanical skills but i couldnt imagine pulling the intake on this thing i think id rather be shot at and i already put fresh oil in it it looked like it hadnt been changed in eons i also added a quart of lucas but its not magic enough to fix it are there any other options thanks a bunch
  #2 (permalink)
Old 06-20-2009, 07:19 PM
cmorningstar01's Avatar
cmorningstar01 cmorningstar01 is offline
1997 Ford F-150
cmorningstar01 is starting off with a positive reputation.
It is possible that the ball tips on the pushrod are scored from inadequate lubrication and have worn the inside of the rocker arm where they make contact, I had this problem on my 97 4.2, When I first got the truck it already had 160K plus miles on it and it was noisy, The pushrod eventually wore its way thru the rocker and I was forced to pull the valve covers and replace the rocker, I just recently put a set of roller rockers on my truck and when I took all the old rockers off some were showing the same wear that the one that had punched thru did(ball tip on push rod scarred)I went ahead and replaced all the pushrods along with the new rockers and the truck runs very smooth and quiet now, To get to the point is that you may have a rocker arm/push rod with wear.
Val
__________________
1997 Ford F-150 Standard cab long bed 4.2 V6 Auto 3:55 gears, Flowmaster SIDSO catback system, Harland Sharp 1.8 Roller Rockers
2002 Mercury Sable LS Premium 3.0 24 valve V6
2001 Ford Windstar LX 3.8 V6 long wb(dog mobile for hauling the lab gang)only 2 seats upfront
  #3 (permalink)
Old 06-21-2009, 04:39 PM
thanks for the info ill pull the valve covers and check it out
Tags
2001 , 42 , ford , lifters , noise , push , replacing , rod , sable , tapping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
