E40D standalone
E40D standalone
In theory, several of us here are discusing this, the motorsport 351 lightning overlay MAF kit works with the E40D question is are the tranny pinns the same on your existing plug as with the overlay plug and are you able to swap the four injectors, actually strait across two for two to make the firing order correct?
Good Luck and let us know whhat happens
Dusty
F-250 now 350 4x4 ext cab SB Green Monster (Used to have)205000 miles, Mass air 460 w/ performance heads, E40d to 5spd conversion, 205 T-case, 4.11 gears, Power-Lok equipt dana 60 front, Doug Thorleys and swapped in EFI 33 gallon bronco rear tank. 33's on 16x8" Outlaw II's, Truck is destined to be a 5.9L cummins diesel 5spd.
Dusty
E40D standalone
i just looked at their web site (thanks for the tip!) and it looks like for a 400 "cleveland" (big-block bolt pattern) in a '75 ranchero, my choice is either a c6 or an e4od. i'd really like to have overdrive, so in that case the e4od is my ONLY choice, right? approximately how much does the baumann electronic unit cost?
thanks,
thanks,
E40D standalone
Yes, to put an Automatic overdrive trans behind a 400 there is only ONE choice. There were apparently a few 400's built with the small bellhousing pattern, but those are rare as hen's teeth.
So, you're back to the E40d. I got one out of a wrecked 90 f250 4x4 that had a 460 engine. I'm trading the engine to a guy who wants the computerized engine in a street rod, and he's trading me his old 460 core for doing all the labor to exchange my old 4 speed for the new E40D and Borg Warner t-case.
There were lots of complaints about these transmissions until 95 when they made several upgrades that cleaned them up.
I checked with my transmission shop who told me to rebuild the old one and install all the upgrades would run about a thousand dollars. A bargain I think. I won't do it yet, cause i may not need the overhaul yet. These are the same trans that's behind the powerstroke diesel!
The Baumannator shift computer costs 400 plus shipping (5 bucks to Kansas). I'm expecting it this week and will have info about how well it works in a week or two hopefully.
tt
tt
what is the web address for this product
tt
tt
Midnite1987
10-23-2017 10:14 PM
wevie
10-26-2016 04:50 PM
