Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Bio-diesel, Propane and Alternative Diesel Engine Fuels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-20-2009, 03:11 PM
Condor99 Condor99 is offline
1987 Ford F-250
Condor99 is starting off with a positive reputation.
Fuel system upgrades to make biodiesel/WVO compatible?
I have an ’87 F250 6.9l with Banks turbo. Want to convert to run 100% WVO and/or biodiesel blend out of front tank and looking for guidance on all the changes I should make to fuel delivery and return system. If people have suggestions for parts/manufactures and ballpark costs too, that’d be great. Already in process of:
· Replace mechanical lift pump with facet duralift to be mounted after tank switch vale on frame
· Bypass water separator and use racor combined filter and water separator
Looking for guidance on the rest, including:
Heating:
· Additional inline fuel heating: necessary and where in line and any recommendation on what to use?
· In tank fuel heater: Eletrice or coolant based? Thermostat?
Fuel line and seals
· Fuel and return lines – material, brand?
· Seals – injector return line cap o-rings?, IP seals? Any other seals (tank selector valve)?
Filtration
· Any additional in-line filtration? # of stages, micron, parts, location (frame, engine bay)
Thanks in advance for the advice.
Tags
69l , biodiesel , compatibility , compatible , diesel , ford , fuel , heaters , inline , line , make , oil , trucks , veggie , wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
