C1 axle - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
C1 axle
Old 06-20-2009, 01:04 PM
desert sled desert sled is offline
desert sled is starting off with a positive reputation.
C1 axle
I am in the middle of changing oil in my rear differential. I just want to be positive my axle is limited slip. It is labeled as C1, but there is are no "L" in any of the descriptions. I am ready to fill,just want to be sure. Thanks for taking care of all the newby questions.
Old 06-20-2009, 01:09 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
C1 is LS. That's what I have. Are the tags on the rear-end in bad shape where it can't be read? Either way it won't hurt a non-LS axle by putting in the friction modifier. No clutches to help slip! Just don't put in too much. If you do, you have converted your Limited Slip to Limited GRIP! AKA an open diff...
Old 06-20-2009, 01:10 PM
Izzy351's Avatar
Does yours have the clutch pack in it like this:
Old 06-20-2009, 01:20 PM
Thats what I have, I will go fill it up. Thanks for the quick response.
Old 06-20-2009, 03:05 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Another good check for LS is to have both wheels off the ground and turn one wheel. If the other wheel turns in the same direction you have LS. If the other wheel turns in the opposite direction you have an open differential.
Old 06-20-2009, 04:10 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
Is an open differential bad or are they two types or systems?? Had to ask, just wondering...
Old 06-20-2009, 04:23 PM
PaysonPSD's Avatar
Quote:
They are to different types of differentials. An LS will drive both wheels. An open diff will only drive one wheel.
Old 06-20-2009, 04:35 PM
big poppa's Avatar
Quote:
Gotya, Thanks Robin.
Old 06-20-2009, 06:02 PM
PaysonPSD's Avatar
That's the simple explanation. In turns the LS, with proper amount of friction modifier, will release the outside wheel other wise it will try to drive it at the same speed as the inside wheel and that is what causes "chatter". The outside wheel needs to move faster because it is going a further distance. If the clutches don't release the outside wheel moves slower or in a sense it is locking and releasing, that's what causes the "chatter". That is the nice thing about LS verses most positive drive diffs.
Which Axle do I have greenwhite1 1994.5 - 1997 7.3L Power Stroke Diesel 9 12-21-2010 02:20 AM
axle code c7x 78_f150 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-01-2010 02:38 AM
Dana 44 axle and hubs Ford4x4-JD70AB Clutch, Transmission, Differential, Axle & Transfer Case 0 02-29-2008 05:12 PM
rear axle tag numbers i1dery Clutch, Transmission, Differential, Axle & Transfer Case 25 03-04-2006 04:38 AM
Rear axle flip measurements 49willard 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 02-02-2006 11:25 AM
Tags
2003, 2004, axle, c1, code, f250, ford, fords, rear, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
