99 ranger 3.0 engine chirping,squeeking noise? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-20-2009, 10:27 AM
M1000 M1000 is offline
M1000 is starting off with a positive reputation.
sounds just like when a belt or idler pully goes out.so i took belt off and still chirps out of engine at idle rpms.any ideas.180000 miles,thanks
Old 06-20-2009, 02:35 PM
Traxxis's Avatar
Traxxis Traxxis is offline
Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.
You could be grinding a bearing... idk?
Welcom to the forums.
Old 06-20-2009, 04:27 PM
scsnls scsnls is offline
scsnls is starting off with a positive reputation.
I had a similar sound and it ended up being Cam Position Sensor, sounded just like a chirping belt.
Old 06-20-2009, 07:29 PM
thanks guys.after some internet searching.somebody said 98 3L Chirp Noise on startup - Car Forums and Automotive Chat take off the camshaft senser cap thing and put a little oil in there.i used wd-40 instead and the noise is gone.cool
might still need to replace someday but i was freaking out is was something major like rings or valves
Old 06-21-2009, 12:43 AM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
FTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to all
My old '99 3.0L had issues with the Idler pulley bearing squealing. I went through (2) two third party idlers before I went to the Motorcraft one. Mine happened at about 135K
Apparantly the third party ones had too much side play.
Old 06-22-2009, 08:19 AM
dorman68 dorman68 is offline
dorman68 is starting off with a positive reputation.
camshaft synchronizer
Old 06-22-2009, 09:48 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Quote:
I concur. Which means that the synchro assembly should be replaced as soon as practical.
A noisy synchro can eventually fail completely, leading to a stripped synchro gear, which means the oil pump driveshaft will stop spinning too, inasmuch as the pump driveshaft interfaces with the gear. This of course causes the pump to stop pumping, starving the engine of oil. These types of catastrophic failures can and do occur.
Old 07-06-2009, 10:25 PM
thelonerangerxlt's Avatar
thelonerangerxlt thelonerangerxlt is offline
thelonerangerxlt is starting off with a positive reputation.
Exclamation Very common problem with the 3.0.
Due to a design flaw, the 3.0 cam synchronizer top
bushing gets oil starved, and that's what causes the
squeaking.
If the synchro's not replaced, the bushing will either
bind up the shaft and strip the gears, or the bushing will
grind itself up and create enough play to destroy the
vane and sensor.
It's not a question of 'if' your 3.0 will have a cam synchro
to fail, but 'when'.
Mine started squeaking with only 55K miles on it......
Old 07-08-2009, 02:34 AM
dart7383's Avatar
dart7383 dart7383 is offline
dart7383 is starting off with a positive reputation.
Do you guys think it would be good preventative maintenance to oil it from time to time? I haven't looked, is it a pain to get to? I'm kind of planning on keeping my truck until the end of time, so I'm willing to do things to keep it healthy for a good long time.
Old 07-18-2009, 11:26 PM
Lightbulb
Oiling the bushing is indeed a good idea.
You can remove the sensor by unscrewing the two
hold-down screws (5.5mm), then lifting up on the
sensor. Then drip a few drops of oil into the 'uphill'
side of the synchro, so it will drain down toward
the shaft and bushing.
A small drinking straw works good to apply the oil,
by filling the straw end with oil and holding/releasing
suction with your thumb on the other end.
Old 07-18-2009, 11:45 PM
rangerte rangerte is offline
rangerte is starting off with a positive reputation.
Cam positioner/Synchronizer
Just going through same exact scenario with my 02 Ranger 3.0L V6!Got my Bro,to listen(ACE MECH.)Got it ,right off as soon as hood opened:He said:Camshaft Synchronizer assembly.Rockautoparts.com $38!Beats EVERYBODY!BUT,you gotta make sure to get it to TDC on Crank pulley,etc. See previous posts search Camshaft Synchronizer assembly replace.YOU gave me an idea tho,I'm gonna oil mine too!I know I gotta replace it.Got the Part in truck too.The "chirp" finally went away,NO Check Engine light either.I know that don't mean its OK.I just got some Health issues right now.I'm gonna Oil mine too ,even tho noise went away.Buying time is my game.Procrastinator is my name!
Old 07-30-2009, 02:05 AM
ticker ticker is offline
ticker is starting off with a positive reputation.
Agreed, guys, It's the syncro assembly and yes it does get oil starved.
I had the same problem and it's an easy fix. Take off the hood and make sure you can see straight down onto the assembly. Take off the sensor.
the top of the syncro assembly looks like a cup with 2 to 3 small nothches and one big notch that the lobe passes for the sensor. Mark the position of one of the small notches on the sycro to the block. Turn the crank until the the lobe lines up with the big notch at the top of the syncro.
(When the engine runs the lobe spins and when it passes the big notch the sensor picks it up.) Take off the one bolt that holds down the assembly and remove slowly. Reinstall the new one in the same position and make sure its all the way in and sitting flat on the block. It has to be in the exact same position. This may take a few tries.
Old 07-30-2009, 07:15 AM
Since the Cam/synch assembly "tie" in with the oil pump,could this cause a "Twitching Oil pressure gauge needle"? Since my original post i.e."Cam Positioner noise"&Synch replacement",I wondered about this.When I drive Long distances,say 50-100 miles ,when I'm at idle after a "Cruise" ,the Oil needle "Twitches ,something "Fierce"ONLY at Idle.Upon Revving slightly,the "twitch" disappears,until idling!I'll re-post or start a new one ,as I've got the Part(Sending unit) awaiting replacement.Thanks
Old 08-01-2009, 02:33 AM
That"s what I thought, but I found out the two weren't related. The oil pressuure switch is an easy fix. Replace that and the needle will stop jumping.
Old 08-01-2009, 04:07 AM
Thanks Ticker,I wasn't sure about that!Now I believe I can move on and not worry about this gauge thing! I still gotta get to my CamSync.! My Bros coming up soon,asnd is THE man for this.He said he could change my Camsync in half hour or so.So thanks to all ,and to all a good night!
squeaksqueaksqueaksqueaksqueak seattle smitty Ford Inline Six, 200, 250, 4.9L / 300 13 06-06-2016 05:22 PM
Help!! Plz newb here 6.0 chirping loud Mikelangevin 1999 to 2016 Super Duty 8 04-10-2016 01:09 PM
Chirping Noise? Easy, Low Tech Fix! turbinefix 6.4L Power Stroke Diesel 1 02-13-2016 07:30 PM
Chirping coming from under truck when decelerating with tow/haul engaged hasteranger 6.0L Power Stroke Diesel 14 07-27-2015 12:40 AM
300 I6 Engine chirp tsuydan 1987 - 1996 F150 & Larger F-Series Trucks 1 02-22-2015 09:47 PM
Tags
2002, 30, 99, assembly, cam, camshaft, chirping, engine, explorer, ford, noise, ranger, squealing, synchro, synchronizer, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
