99 ranger 3.0 engine chirping,squeeking noise? - Page 2 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-05-2009, 01:40 AM
ticker ticker is offline
ticker is starting off with a positive reputation.
You really can do it yourself, it's easy. But if your brother is going to do it
let him know it's easier with the hood off, but before he takes it off, have him drill a hole between the two bolts on each hinge and insert a dowel pin, that way when he puts the hood back on he doesn't have to re align the hood.
Old 09-29-2009, 01:54 PM
rs92stockie rs92stockie is offline
rs92stockie is starting off with a positive reputation.
same type of problem
Hello, I have the same type of problem, a squeeking noise. I have changed the Idler and tensionner pully, the alternator, waterpump and belt has also been changed. The problem persist with all those pieces changed through the years (it's making this noise when it rains and/or the humidity is high)
Now today, I found this thread with the CPS and synchro. I tried to put some oil after removing the sensor and it did not change the sound. Now, the noise clearly become from the front of the motor, so i'm asking myself if the Synchroniser would make the noise at the front if it is at the back of the motor... Could someone help ? I did a short video, I'll try posting it.
Here's the video : http://www.youtube.com/watch?v=YU9gGVktbaE
Old 09-30-2009, 12:19 PM
rangerte rangerte is offline
rangerte is starting off with a positive reputation.
It's CLEARLY IN the Back of your Engine! At least on My 3.0V6! My brothers been a mechanic for 30 some years.Before I had the hood opened,Engine running,He diagnosed it! "Camshaft Synchronizer" ,He said! I ordered one from Rockautosoupply.com $37! Much better price then the "Bib Boy franchises! I dropped a few oil drops from a "Zoom Spout" oil bottle,we used in Motors(electric A/C,etc.)using my usual5W20 Synthetic Blend Motorcraft Ol.I HOPE I'm buying time? Because,this Is Not the resolution of the problem.At best,A Very,Very,temporary "noise reduction ,ONLY!Gotta replace it NOW!Back by the Bell Housing! NOT on the front.I didn't read your whole post,so what Engine you got?
Old 09-30-2009, 12:22 PM
I have a Ranger 2002 3,0L V6... the noise seems to come from the shaft for the radiator fan. Did you hear the video ?
Old 10-01-2009, 12:17 AM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Take the fan off and see if it makes the noise, that will eliminate the fan shaft as the source.
Old 10-01-2009, 02:53 PM
I forgot to say that the fan clutch have been changed too, so it eliminate this piece too... even if I remove the fan, the noise from de shaft would be there ?
Old 10-02-2009, 05:30 AM
killit's Avatar
killit killit is offline
killit is starting off with a positive reputation.
thats a serious squeak. hard to say from a video but that doesn't sound like belt noise to me, and if its definitely from the front i'd say one of your pulley's or shaft bearings wore out.. Just from the noise, it sounds very "metallic" to me thru the computer... is that the way it sounds to you? like its making some very fine metal shavings dry metal on metal contact?
Old 10-02-2009, 08:49 PM
yeah, and as you say, it sounds metallic... There's no more belt/pulley to change... Is there a bearing for the shaft of the fan that I can change ? As I said, the sound only appear when there's a lot of humidity in air and when it rains.
Old 02-16-2011, 07:27 PM
cwcrossan cwcrossan is offline
cwcrossan is starting off with a positive reputation.
Ford ranger 3.0 engine chirping,squeeking noise
2003 Ranger Edge, 3.0L Flex Fuel, 117,200 miles. Noise sounded like belt pulley. Changed belt and tensioner, noise persisted. Red this thread, and placed stethoscope directly on camshaft position sensor to pinpoint noise. Removed sensor cap and sprayed WD-40 down into the sensor. The noise went away. Researched replacement part, Dorman 689-117, Summit Racing $39.95. Great job to Yahoo web search and Ford Truck Enthusiasts. Lesson learned: Have a problem, look here first. Thanks.
Old 06-17-2014, 07:49 AM
rogerdas rogerdas is offline
rogerdas is starting off with a positive reputation.
I have 08 Ranger and replaced belts alternator, harmonic balancer, and still faint squeak, don't know if because used after market parts or what, truck seems fine or is there a better way to check camshaft sycn
Old 06-17-2014, 09:59 AM
Squeaking Noise From Ranger 3.0 engine
See my thread on camshaft positioning sensor, also know as camshaft synchronizer. Sits at the back top deck of the engine, and acts like a distributor by pointing to a sensor to tell computer which cylinder to fire. Determined by the position of the camshaft. The gear and shaft that is driven by the camshaft becomes worn and begins to squeak. To verify the part is defective can listen with stethoscope or just remove cap/wire connector and squirt some WD40 down to lubricate the gear. The noise will go away for awhile, but later comes back. I eventually replaced the camshaft positioning sensor Dorman's 689-117, no problems since.
Old 06-18-2014, 08:17 AM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Quote:
Welcome to FTE.
Would be helpful to know which end of the engine compartment the squeak is coming from & which engine your Ranger has. If its the 3.0L Vulcan, then your correct to put the cam sync assy on your under hood squeak suspect list if the noise is coming from atop the passenger side, firewall end of the engine compartment. Apply your stethoscope to the cam sync to determine if its causing the noise. Its located atop the engine, passenger side firewall area, back where the distributor was located years ago.
If you don't have a stethoscope, we can fashion one from a wooden dowel, like a broom handle, or a long screwdriver, or use a length of tubing, or hose, one end on the suspect, the other end to our ear. If its not the cam sync, listen to other rotating bearing parts to see if you can locate the squeak area. Idler & belt tensioner pulleys, along with the water pump bearing, are common problem parts in front/radiator end of the engine compartment squeaks. Make sure the serp belt tension is within the molded in tension range marks on its casting & that all serp belt driven accessories pulleys are in good edge to edge alignment & a straight edge can be used to check that.
As has been said, if its the cam sync assy causing the squeak, best to replace it without delay, as that engines oil pump is driven off it & if the part fails by seizing, its gears will strip & the oil pump will stop doing its thing, so we'll soon loose an engine. Motorcraft parts are recommended, as there have been pre-mature failure reports on some after market parts.
Carefully note, or mark the cam sync/sensor assy position Before removing, as the new one Must go in & align Exactly the same way, or fuel injector timing will be off.
More thoughts for consideration, let us know what you find.
  #28
Old 06-18-2014, 09:12 AM
Rockledge's Avatar
Rockledge Rockledge is online now
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
If you suspect a CMP synchronizer problem, this thread is a little long, but worth the time to read through:
http://www.ford-trucks.com/forums/20...placement.html
  #29
Old 08-12-2015, 06:13 PM
Rangermonster Rangermonster is offline
Rangermonster is starting off with a positive reputation.
I have a loud squeal that sounds like is coming from the back of my truck but only seems to do it in second and only does it every now and then but when it does it does does it all day could this be the sensor?? Or could it be a berring or spacers vibrating against the brake drum or what???
  #30
Old 08-18-2015, 02:49 PM
Does the squeal sound like metal on metal, more like a grinding, or is it more like metal sliding against something? Please start a new thread for more and better specific answers. Is the noise coming from the back of the truck only when it's moving?
Try to jack up the rear end the next time it happens and see if there's a change.
squeaksqueaksqueaksqueaksqueak seattle smitty Ford Inline Six, 200, 250, 4.9L / 300 13 06-06-2016 05:22 PM
Help!! Plz newb here 6.0 chirping loud Mikelangevin 1999 to 2016 Super Duty 8 04-10-2016 01:09 PM
Chirping Noise? Easy, Low Tech Fix! turbinefix 6.4L Power Stroke Diesel 1 02-13-2016 07:30 PM
Chirping coming from under truck when decelerating with tow/haul engaged hasteranger 6.0L Power Stroke Diesel 14 07-27-2015 12:40 AM
300 I6 Engine chirp tsuydan 1987 - 1996 F150 & Larger F-Series Trucks 1 02-22-2015 09:47 PM
Tags
2002, 30, 99, assembly, cam, camshaft, chirping, engine, explorer, ford, noise, ranger, squealing, synchro, synchronizer, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
