Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-20-2009, 09:42 AM
66 BADBOY 66 BADBOY is offline
66 BADBOY is starting off with a positive reputation.
2005 to 2007 17" wheels, how wide are they? Fit a 33x12.5x17?
I'm assuming that all the 17" wheels (basic chrome, modular holed, Lariat, etc) on the 05-07 are the same width. But what is the width? 7.5", 8", 8.5"? I tried to find it on the OEM catalogs, etc, and it's not listed.
I'm trying to figure out if you can fit a 33x12.5x17 on the stock wheels. From some of the tire sites I've seen, they recommend an 8.5" wheel as a minimum width for the 12.5 wide tire.
Anyone know what the stock wheel width is?
THANKS!!
__________________
My motto on life: Don't EVER look back, just flush.
  #2 (permalink)
Old 06-20-2009, 10:24 AM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian is gaining momentum as a positive member of FTE. Furian is gaining momentum as a positive member of FTE.
The 2006 Super Duties came with the following wheel size options:
WHEEL SPECIFICATIONS
Wheel Type Wheel Size
Nominal
Inset mm
(in.)
No. of
Studs
Bolt
Circle
mm (in.)
Max. Wheel
Capacity
Load (lbs. @
ground)
Argent Painted Steel (F-250-350 SRW) 17
x 7.5J 40 (1.57) 8 170 (6.7) 3195
Chrome Steel (SRW) (F-250-350 SRW) 17
Forged Polished Aluminum (SRW) (F-250-350 SRW) 17
Premium Forged Aluminum (SRW) (F-250-350 SRW) 17
Argent Painted Steel (F-250-350 SRW) 18
x 8.0J 40 (1.57) 8 170 (6.7) 3525
Chrome Steel (F-250-350 SRW) 18
Forged Polished Aluminum (F-250-350 SRW) 18
Premium Forged Polished Aluminum (F-250-350 SRW) 18
King Ranch Painted Aluminum (F-250-350 SRW) 18
Polished Forged Aluminum (F-250-350 SRW 4x4) 20
Argent Painted Steel (F-350 DRW) 17
x 6.5J 142 (5.55) 8 200 (7.87) 3195
Forged Polished Aluminum (F-350 DRW) 17
Steel (DRW) (F-450-550) 19.5
x 6.0RW 136 (5.35) 10 225 (8.85) 3750
Polished Aluminum (DRW) (F-450-550) 19.5
x 6.0RW 127 (5.00) 10 225 (8.85) 3750
Go to Page 32 for details:
https://www.fleet.ford.com/truckbbas...essd-ms_06.pdf
__________________
Andrew
2005 F-350 4X4, Regular Cab Long Bed, XL Package, 5.4L 3V Engine, TorqShift®, 4.10 Limited Slip, K&N CAI Kit, SCT Livewire w/ Custom Tunes from 5 Star Tuning
  #3 (permalink)
Old 06-20-2009, 10:26 AM
Thanks a million for that info!! Great job!!
Although it looks like the stockers won't work with the tires I'm after.
__________________
  #4 (permalink)
Old 06-20-2009, 10:51 AM
Furian's Avatar
I have a brand new set of five 18X10 wheels if and when your in the market...
__________________
Andrew
  #5 (permalink)
Old 06-20-2009, 11:57 AM
Robs06SuperDuty's Avatar
Robs06SuperDuty Robs06SuperDuty is offline
2006 Ford F-250
Robs06SuperDuty is starting off with a positive reputation.
yeah you're gonna want atleast a 8" wide wheel for a 12.50 width tire and at most a 10" wide wheel. 8 inch will just cup a little more. my lariat wheels are 18x8 and the tires arent cupped too bad.
__________________
Robby
06 F250 5.4L SC LB 4x4
Plow Package, Leveling Kit, Bilstein HD's
Cooper Discov STT 35x12.50x18's
Rough Country Dual Stabilizer Kit
K&N Drop in and Flowmaster Super 40
  #6 (permalink)
Old 06-20-2009, 12:10 PM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident Smarta$$
2004 Ford F-250
D8chumley is gaining momentum as a positive member of FTE. D8chumley is gaining momentum as a positive member of FTE.
I have 37/13.5-18's on 18x9 wheels, no problem. You should be fine with a 12.5 on your stock wheels, even though they say they don't recommend it. Just my .02
__________________
'04 F250 KingRanch CC FX4 6.0 swb "BIG D"
Tim
GO FLYERS!
Originally Posted by hubler13f
When congress refuses to provide soldiers with the equipment to complete the mission. S.T.E.A.L. Sudden Transfer Of Equipment to an Alternate Location
  #7 (permalink)
Old 06-20-2009, 12:36 PM
cparks cparks is offline
2005 Ford F-350
cparks is starting off with a positive reputation.
I would not put those tires on a 7.5 inch wheel. The 9 inch will be great and keep the tread nice and flat.
__________________
Clayton Parks - Michigan
05 Ford SuperDuty 6.0 PowerStroke 4x4 Toyo Hypertech Magnaflow
57 Ford Ranchero 4x4 390 project
  #8 (permalink)
Old 06-20-2009, 12:57 PM
D8chumley's Avatar
Resident Smarta$$
2004 Ford F-250
I didn't look and see they were 7.5, I assumed they were 8 inches wide. If you can afford new wider wheels it would be better. I have seen F250s with 35's on the stock 17" wheels, though.
__________________
Tim
GO FLYERS!
  #9 (permalink)
Old 06-20-2009, 01:34 PM
FX4 5.4's Avatar
FX4 5.4 FX4 5.4 is online now
FX4 5.4 is starting off with a positive reputation.
hey furian, you getting rid of your stock 18's when you put the others on?
__________________
2005 Ford F250 Super Duty XLT 4x4 5.4L V8 SuperCab Short Bed "Jenny"
A few mods now, but more to come.
  #10 (permalink)
Old 06-20-2009, 01:37 PM
2005 Ford F-350
Quote:
Yes I think many people do this, though it causes the center of the tire to bulge out and wear funny. I would think they would not handle so well either.
__________________
  #11 (permalink)
Old 06-20-2009, 01:43 PM
Furian's Avatar
Quote:
Yes Sir... and the tires too. They are LT275/75R18E Michelin LTX A/T2's with 7K miles.
__________________
Andrew
  #12 (permalink)
Old 06-20-2009, 04:08 PM
I was messing around with a converter that I made up in Microsoft Excel, and a 285/70/17 works out to be very close to a 33x12.5x17 (it works out to be 32.7x11.2x17). Now I know they don't make a "11.2 inch" wide tire, but really what that means is that a 285/70/17 is only 1.3 inches narrower than a 33x12.5x17.
Seeing that you can mount the 285/70/17 on a stock 17" wheel, it would be way cheaper just to do those tires and forget the additional 1.3" width. Yeah, the 12.5 would look better, but I couldn't justify the cost to get them by time I had to buy new wheels.
Theoretcially, it should look the same from a side view. Just won't have the width.
__________________
  #13 (permalink)
Old 06-20-2009, 05:44 PM
reefman's Avatar
reefman reefman is offline
reefman is starting off with a positive reputation.
Or do 285/75-17. Those work out to be 34"x11.5. A little taller and still work with the stockers. That's what I've got and they look much better than the original 265's. Your choices do become rather limited though with the 75 series. Just depends on the tire you're after.
  #14 (permalink)
Old 06-20-2009, 08:05 PM
Furian's Avatar
EDIT: The correct tire size is LT275/70R18E, which are 33" tall.
__________________
Andrew
  #15 (permalink)
Old 06-24-2009, 06:45 AM
crmarshall crmarshall is offline
crmarshall is starting off with a positive reputation.
I have ran 35x12.50 tires on 8 inch wide wheels on the last three trucks I have owned. My F150 got 50K miles out of BFG MT's on those wheels. I never noticed any cupping or wear and I am very particular about monitoring tire wear. I first had 10 inch wide wheels put on the last F150 and the wheel was actually a little too wide in my opinion. Remember, a 12.50 inch wide tire only has an 11 inch wide tread in most cases.
__________________
[/SIGPIC]
2005 F250 Crewcab XLT Lariat FX4 6.0 PSD
4" tough country lift.
4" exhaust with Banks muffler.
35" Toyo O/C on 18" wheels.
AFE cold air intake.
Firestone Airbags with compressor.
Turbo Liner
Auto Meter NV EGT gauge.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
