Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-20-2009, 02:13 AM
yellar yellar is offline
yellar is starting off with a positive reputation.
howl noise
my 2004 fx4 5.4 has a howling noise when i reach 80 km/hr. if i speed up to 90 the howl goes away. it only seems to howl at 80?? any one have any ideas what could be causing the noise? i have only owned the truck for a few months. noise has been going on for a while now. truck is showing 80000 kms.
  #2 (permalink)
Old 06-22-2009, 03:49 PM
AlbusPlaustrum06's Avatar
AlbusPlaustrum06 AlbusPlaustrum06 is offline
AlbusPlaustrum06 is starting off with a positive reputation.
Quote:
Tires?
Differential(s)?
Full moon?
My 98 had bad tire noise at certain speeds unless it was raining. Improper inflation on my part. I had howl from my dif on my 94 at anything over 50kph until the thing died, dang speed sensor crap.
  #3 (permalink)
Old 06-22-2009, 05:41 PM
BlueOvalFitter BlueOvalFitter is offline
BlueOvalFitter is starting off with a positive reputation.
Talking
A werewolf under your hood?
Seriously,I think there is a TSB on howling differentials that year.
__________________
2007XL R/Cab,4.2 V6,auto
The anticipation of death is worse then death itself!
  #4 (permalink)
Old 06-24-2009, 12:10 AM
if it is the diff does that mean something is wrong or is that just how they are for that year?
  #5 (permalink)
Old 06-24-2009, 12:53 PM
Fishin76 Fishin76 is offline
Fishin76 is starting off with a positive reputation.
My read end howls on my 4x4 screw, has since i bought it with 66k miles
I've had no problems.
__________________
These are not the Droids you are looking for.....
Current vehicles:
98 Contour 2.0L auto, my new DD 49K 30mpg
2009 Dodge Grand Caravan SXT 3.8L 6sp auto
1986 F250XL Diesel RC LB 4x4 T19 4spd 4.10's?
  #6 (permalink)
Old 06-24-2009, 09:32 PM
im not for sure but if it was my diff....wouldnt it be making noise at all speeds rather than just at 80 ?
  #7 (permalink)
Old 06-30-2009, 01:56 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is starting off with a positive reputation.
No. rears are very speed-related as far as the whine or howl is concerned. If it were a wheel bearing or tire, then it would make noise at all speeds. You might consider changing the oil in the rear and using the full-synthetic factory part to replace it.
  #8 (permalink)
Old 07-04-2009, 04:15 PM
mswpj mswpj is offline
mswpj is starting off with a positive reputation.
Probably the diff. Mine did the same thing. $1500 dollars later, it was fixed. If you have it looked at, and it needs to be repaired, push for FORD oem ring and pinion. I had two different aftermarket ones in my diff and they whined right from the start. rear end whined from 45-50mph accelerating only.
  #9 (permalink)
Old 07-04-2009, 06:15 PM
ChargersFanInCO ChargersFanInCO is offline
ChargersFanInCO is starting off with a positive reputation.
Ring and pinion too tight will make it howl at various speeds. Too much preload...Usually.
  #10 (permalink)
Old 07-05-2009, 11:44 AM
just had the truck in at alberta driveline. i went with the mechanic for a test drive, when he heard the noise he told me he thought it was the crown and pinion set. he also said it is caused from too heavy of a load either in box or from trailer. i asked if it was necessary to get fixed right away, and he said i could leave it for up to 3 years with no problems except for the noise. 1000 to fix
  #11 (permalink)
Old 07-05-2009, 01:46 PM
slomafarms slomafarms is offline
slomafarms is starting off with a positive reputation.
had the same prob on my 04...took it to the dealer and the compleatly rebulit the rearend under warranty...3 days later it started to howel again
__________________
86 f150 "farm truck" 351W C6 long box reg cab
99 f250 XLT 7.3 PSD scab long box 300,000 on the clock and runs like a champ!
04 f150 XLT 5.4 4x4 screw short box-stock for now
05 f250 XLT 4x4 "service truck JR" 6.0 PSD w/service body
08 f250 XLT 4x4 screw short box 6.4 PSD
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
