y-block crank case vent
MANY people have done that very thing. I'm planning to use a PCV valve from an OMC 460 marine v-8 on mine.
They did? ......hummm, I didn't know that, (and lots else too) as albuq f1 says there is a diff between a PVC and a vent hose
anyway,........Welcome to the site.
It would depend on your engine condition and how much liquid vapor (oil) it is putting out, some liquid could congeal at the lowest point in your hose and if excessive would require draining. I tried that with a tractor that had real bad blow-by and it was too much for the air-fuel mixture.
What’s wrong with drip vent you have now?
I believe some of the last 292 y/blocks in 1964 had that system, I have one that has a different outlet from the top valley cover and The front left canister and tube have a cover plate. The rest of the parts are missing . I am trying to find out if this was factory installed as the valley cover doesn't look like it has been modifide .
My '60 has a PCV valve, but I think it was an add on by the PO. There is a tapped vacuum fitting (normal size for a PCV) in the rear of the intake that goes to a PCV Valve that is in the rear of the valley cover. It seems to run fine but I don't know if anything underneath the cover has been changed.
Open Crankcase Vent
This is why race engines all have open breathers and why trucks which carry loads or tow have to retrofit a unit called Vac-u-pan to eliminate their oil leaks. This is a siphon type system added to the headpipes which has a valve and two hoses go to the rocker covers. When a lot of exhaust is flowing, vacuum is created which then relieves the crankcase pressure. The blowby goes out the exhaust system and is handled by the catalytic converter if equipped.
So if you are allowed in your state to have an open crankcase, I would leave it that way. Advantages include a clean air cleaner, carburetor, less sludge in the crankcase, and no oil leaks propelled by pressure.
Regards,
Alan
Blowby
Incidently, the crankcase vent on a Y block has a baffle and a filter (which in the case of a high blowby engine must be cleaned frequently), and on a flattie, the blowby from '49 on comes out of the intake manifold into a road draft tube.
Alan
thanks skips 56
