Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #46 (permalink)
Old 08-22-2009, 07:14 PM
jsutton's Avatar
jsutton jsutton is offline
1977 Ford F-100
My Garage
jsutton is starting off with a positive reputation.
Ok I just got through testing my compressor. I'm not sure how hard it's supposed to suck on the suction side, but it was sucking in and putting out air!! There was also a little oil spraying out on the high side, is that supposed to do that? I made a short video of it running I know it was squeaking some but I think that's because I didn't have the belt tight enough. In the video you can see me stick my finger to the valve for a demostration of how hard the suction is. It's very short because the sd card is almost full. If you want to, check it out.
__________________
'77 F100 302 C4 John Deere Blitz Black and Cragar Soft 8s
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=202355&.jpg
  #47 (permalink)
Old 08-23-2009, 07:31 AM
tomw tomw is offline
tomw is gaining momentum as a positive member of FTE.
Two things: From what I know, the oil is carried around the system by the refrigerant. They mix together kind of like gas and oil mix for a two-stroke chainsaw. I think the majority stays in the sump, and what is carried out by the refrigerant supposedly makes its way back.
The second: You painted the compressor blue. I have never seen a York in any color other than black. Guess you had to be creative, eh?
By the way, don't run it a whole lot w/o refrigerant as you'll lose the oil and, maybe, there may be a little cooling effect from the incoming gas. Heck, I'm not an engineer, but slept in a Motel-6 ...
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #48 (permalink)
Old 08-23-2009, 10:38 AM
lsrx101 lsrx101 is offline
lsrx101 has a good reputation on FTE. lsrx101 has a good reputation on FTE.
That "looks" like the compressor is doing what it's supposed to do. tomw is corrrect about the oil. You will get some in the discharge but the majority will stay in the sump.
I sure hope you're running it like that with the old oil and plan to change it. That oil will be moisture saturated now. You will need to flush the crankcase 2-3 times with fresh oil. You really shouldn't run it like that while open to the atmosphere.
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
  #49 (permalink)
Old 08-23-2009, 10:44 AM
jsutton's Avatar
1977 Ford F-100
My Garage
I painted it blue to to match, I wasn't worried about it being correct. That is about all I ran it right there. I didn't run it over 2 minutes total. I was just testing it. I took it right back off the truck after I did this video. I left the brackets in place but I took the compressor off.
Is that how hard it's supposed to suck? I hope so, because that means all I need now is the condensor, drier, and lines.
EDIT: I do plan to change the oil one more time before I mount it permanently.
Thanks,
__________________
Tags
100 , 1999 , 77 , ac , bad , check , cleaning , condensor , core , ebay , evaporator , f250 , ford , pressure , test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
