Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-19-2009, 10:02 AM
Pat M Pat M is offline
Pat M is starting off with a positive reputation.
Strange Sound from Drive Train
My 93 Ranger, 4.0 with a 5-speed manual transmission, is making a strange noise when I take the truck out of gear and roll to a stop. It sounds like the spinner on Wheel of Fortune, or a baseball card in bicycle spokes. It sounds like it is coming from the transmission/drive shaft area, and only happens when the truck is rolling in neutral. The noise prompted me to look under the truck and I discovered the left rear leaf spring mount was rusted away, so I had been driving with the rear end out of alignment. I had the mounts replaced on both sides, and the noise is still there. Any suggestions would be greatly appreciated.
  #2 (permalink)
Old 06-19-2009, 11:45 AM
Old93junk's Avatar
Old93junk Old93junk is online now
Old and mean
1993 Ford F-250
Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold
Does it make the sound under power or coasting?.......Clutch in or out?, almost sounds like a clutch throw-out bearing.
__________________
FORCE IT!,IF IT BREAKS IT NEEDED REPLACED ANYWAY!
IF IT CANT BE FIXED WITH A HAMMER, ITS A ELECTRICAL PROBLEM!
Still bitterly clinging to guns and religion.
Dave
Oregon Assistant Chapter Leader: To join the Oregon Chapter, click HERE
  #3 (permalink)
Old 06-19-2009, 05:23 PM
It makes the sound coasting to a stop, in neutral, with the clutch out.  It also makes a slight "clunk" when I put it in gear and take my foot off the clutch.
  #4 (permalink)
Old 06-19-2009, 08:32 PM
Traxxis's Avatar
Traxxis Traxxis is offline
1994 Ford Ranger
My Garage
Traxxis has a very good reputation on FTE. Traxxis has a very good reputation on FTE. Traxxis has a very good reputation on FTE. Traxxis has a very good reputation on FTE.
Have you replaced u-joints? How many miles?
__________________
'94 Ranger XLT Ext. Cab 3.0L 5-speed
'97 Ranger XLT Ext. Cab 2.3L 5-speed
  #5 (permalink)
Old 06-19-2009, 09:15 PM
U-joints were replaced 45K miles ago. The clutch was done 60K miles ago.
  #6 (permalink)
Old 06-19-2009, 10:14 PM
Old93junk's Avatar
Old and mean
1993 Ford F-250
Put all 4 up in the air on jack stands, and get a helper to listen or run the truck. I have had to do this before to pinpoint noises.
__________________
Dave
  #7 (permalink)
Old 06-20-2009, 05:50 AM
El_Jefe's Avatar
El_Jefe El_Jefe is offline
¿Qúe onda amigo?
El_Jefe is gaining momentum as a positive member of FTE.
I got that clunk too. I have narrowed down to the U-joints...hope that helps!!
__________________
1991 Ranger Custom 2.9L V6, Gas/Air Hybrid, 6"Lift w/ 33s
  #8 (permalink)
Old 06-20-2009, 03:47 PM
Took it for a long drive today, and it only makes the noise coasting in neutral. Pressing the clutch has no effect on the sound. Thanks for your help.
  #9 (permalink)
Old 06-20-2009, 03:53 PM
El_Jefe's Avatar
¿Qúe onda amigo?
mine only does it coming out of first...sorry I couldn't be of more help!
__________________
  #10 (permalink)
Old 07-02-2009, 12:04 AM
Replaced the rear U-joint and the truck is good as new! 189K miles and going strong. Check those rear leaf-spring mounts if you drive on salty roads.....mine were rusted away.
Tags
2004 , f150 , manual , noise , sounds , strange , transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
