Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-25-2002, 12:29 PM
wildjon300ci is starting off with a positive reputation.
What type tranny fluid?
Allright ya'll, I got my truck (specs in signature) and I'm about to change the tranny fluid while I'm under there with the X-fer case out. What type of tranny fluid should I use for my C-6? Also, what type of fluid should I use for my NP-208 X-fer case?
__________________
1986 Bronco 4x4 EFI 302
Stock...for now
Wide-ratio C6 :evilgrin:
351 waiting to be stuffed in
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-25-2002, 03:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky has a great reputation on FTE. Mark Kovalsky has a great reputation on FTE. Mark Kovalsky has a great reputation on FTE. Mark Kovalsky has a great reputation on FTE. Mark Kovalsky has a great reputation on FTE.
>for my C-6?
Use MERCON, not MERCON V fluid.
>NP-208 X-fer case?
Sorry, I don't know for the transfer case.
Mark
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #3 (permalink)
Old 01-27-2002, 07:15 PM
Does anyone know anything about a NP208? Thanks Mark for the C-6 answer.
__________________
Stock...for now
  #4 (permalink)
Old 01-27-2002, 08:01 PM
flyboy2610's Avatar
flyboy2610 is starting off with a positive reputation.
Use Type F fluid in a C-6. It is less slipery than Mercon. Too much slip will toast the clutches. The C-6 is designed for Type F fluid.
  #5 (permalink)
Old 01-28-2002, 08:47 AM
According to Ford's TSB 01-15-7 the C6 from 1977 until production ended in 1996 used MERCON fluid.
Mark
__________________
Mark
  #6 (permalink)
Old 01-28-2002, 10:24 AM
AZ4x4f150 is starting off with a positive reputation.
my truck spec for my 82 f150 with a c6 says to use Mercon,DexronIII
my transfer case says use the samething but since my truck goes off-road alot I put SAE 30 in my transfer case it lubes better and keeps the transfer case cooler I have never had a problem with it
If you put SAE 30 in your transfer case just flush it with SAE 30 first then fill it up. I also noticed when off-road i don't hear that whine from the transfer case in 4lo and you let off the gas anymore
  #7 (permalink)
Old 01-28-2002, 01:17 PM
mudslinger_82 is starting off with a positive reputation.
__________________
[br][br][center]
Please feel free to visit my webpage @ [a href="http://www.geocities.com/mikevickig" target="_blank"]Mike & Vicki's Place[/a]
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
