Hard to get into gear when stopped - Ford Truck Enthusiasts Forums
Old 06-19-2009, 03:03 AM
vlasveld vlasveld is offline
vlasveld is starting off with a positive reputation.
Hello everyone, im new here! My name is Ryan and i recently picked up a 1994 f150 with an inline 6
Im just trying to figure out how to fix the problem with shifting in my truck.
When im at a stop the truck is really hard to shift from neutral to first gear... it wont go in unless i really force it. If i shift to 4th then out into first it makes it much easier.
All around the truck doesnt seem to be shifting like it should. Fluid leves are ok and fluid is new.
Any suggestions??? im wondering if it might be the clutch but i really dont know!
Thanks so much for the help these forums look awesome!
ps i should also add its easy to get into first when rolling its just when im stopped at a light its almost like something is blocking it... its bad enough that its definetly not normal
Ryan
Old 06-19-2009, 04:24 AM
i guess i forgot to mention its a manual 5 speed
Old 06-19-2009, 07:58 AM
blakem_85's Avatar
blakem_85 blakem_85 is offline
blakem_85 is starting off with a positive reputation.
Sounds like a clutch problem i'm not too familiar with the light-duty setups though. How does the clutch feel/act when taking off from a stop?
Old 06-19-2009, 08:01 AM
Quote:
Feels a little jumpy, i try to let it out a smooth as possible but its tough. Thanks for the response
Old 06-19-2009, 08:56 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
what do you mean the fluid is new? Also have a look under the dash and check the pedal hinge and rod for worn bushes.
Is it hard to get into reverse as well as first?
Old 06-19-2009, 09:00 AM
Not too sure about reverse, i will test today and see. What does it mean if it is?
Thanks
Old 06-19-2009, 10:24 AM
Ok i just did a little more testing. It happens even when the truck is not running. Reverse is fine and shifts easy.
The problem is bad when going into first gear and all gears dont shift real smoothly
Old 06-19-2009, 10:45 AM
6CylBill's Avatar
6CylBill 6CylBill is offline
6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.
I'm sorry I cannot be of help but I wanted to welcome you to FTE! That 300 won't win any races but it is a realiable motor. I hope your problem is resolved shortly!
-Bill
Ps. Send me a PM if you ever want to start messing with your exhaust. I have sound clips on youtube and I've spent way too much money getting the right sound from my 300.
Old 06-19-2009, 10:56 AM
70torino429's Avatar
70torino429 70torino429 is offline
70torino429 is starting off with a positive reputation.
try letting out the clutch when in neutral, then the second after that put the clutch in and try putting it into first.
i had this problem with my 94 sometimes, except it didnt want to go in reverse. You might have some linkage or bushing related issues though, have you checked the hydraulic clutch fluid reservoir? its near the brake master cyl.
Old 06-19-2009, 04:58 PM
Ok more info! I just noticed its with every gear, i would have to force it in, except for 4th, maybe 5th. Then i can go to first or the other low gears. Also when im just driving normal i feel a slight grind when shifting into any gear its not a grind you can hear.. but you can feel it on the shifter ****.
Letting the clutch out and back in and shifting right away didnt make any difference, also i checked the reservoir and its full! Thanks for the response!
Old 06-19-2009, 05:20 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
You said the fluid level is fine - what about the transmission fluid level? Did you pull out the fill plug and make sure the fluid is right at the hole?
Old 06-19-2009, 07:00 PM
BroncoRoadKill's Avatar
BroncoRoadKill BroncoRoadKill is offline
BroncoRoadKill is starting off with a positive reputation.
mine does basically the same thing.I just down shift and make sure im in 1st before the truck stops. When your having problems getting into gear do you hear a clunk inside the tranny if you try to go back and forth between 1st and 2nd?
If thats the case its slack in the tapered bearings inside the tranny and it just needs to be reshimmed.
When the main shaft get a bit of slack the tapered bearings let the shaft assymbly fall a bit and it drags along the pilot and you just have to hold the clutch in and hold the shifter in 1st lightly untill it slips in.
Mines doing it and I just havent had the time to pull it to take up the slack.
sorry for the long post.
Old 06-19-2009, 07:32 PM
phoneman91's Avatar
phoneman91 phoneman91 is offline
phoneman91 has a good reputation on FTE.phoneman91 has a good reputation on FTE.
Where is the clutch engagement point in reference to the floor??
Does the clutch engage almost at the end of the clutch stoke when releasing the clutch pedal or at the beginning of releasing the clutch -near the floor??
Old 06-19-2009, 08:36 PM
I guess the clutch engages a few inches off of the floor..
When im trying to put it in first and it wont go i do hear a clunk like its hitting something and blocking it.
Old 06-19-2009, 09:08 PM
phoneman91's Avatar
Is there any difference when trying to get it into first -if the engine is running or not running?? With the engine off-is it easier to get the tranny into first??
Lost all forward gears in my 95 f150 e4od NotSoSporty98 1987 - 1996 F150 & Larger F-Series Trucks 4 08-28-2016 04:06 AM
1994 F-250 Transmission shifts hard NinthGenF-SeriesOBS 1999 to 2016 Super Duty 10 03-26-2016 12:12 AM
transmission won't shift out of first Ryan Colpitts 1987 - 1996 F150 & Larger F-Series Trucks 14 08-22-2014 01:59 PM
damn shift!!! Daviddc114 Excursion - King of SUVs 12 03-20-2011 09:30 PM
vehicle speed sensor? bigredtruck 3.0L V6 3 03-03-2011 11:10 AM
Tags
2001, clutch, engages, f150, floor, ford, gear, grinds, hard, manual, pedal, problems, put, putting, shift, stopped, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
