Hard to get into gear when stopped
Hello everyone, im new here! My name is Ryan and i recently picked up a 1994 f150 with an inline 6
Im just trying to figure out how to fix the problem with shifting in my truck.
When im at a stop the truck is really hard to shift from neutral to first gear... it wont go in unless i really force it. If i shift to 4th then out into first it makes it much easier.
All around the truck doesnt seem to be shifting like it should. Fluid leves are ok and fluid is new.
Any suggestions??? im wondering if it might be the clutch but i really dont know!
Thanks so much for the help these forums look awesome!
ps i should also add its easy to get into first when rolling its just when im stopped at a light its almost like something is blocking it... its bad enough that its definetly not normal
Ryan
Ryan
I'm sorry I cannot be of help but I wanted to welcome you to FTE! That 300 won't win any races but it is a realiable motor. I hope your problem is resolved shortly!
-Bill
Ps. Send me a PM if you ever want to start messing with your exhaust. I have sound clips on youtube and I've spent way too much money getting the right sound from my 300.
try letting out the clutch when in neutral, then the second after that put the clutch in and try putting it into first.
i had this problem with my 94 sometimes, except it didnt want to go in reverse. You might have some linkage or bushing related issues though, have you checked the hydraulic clutch fluid reservoir? its near the brake master cyl.
Ok more info! I just noticed its with every gear, i would have to force it in, except for 4th, maybe 5th. Then i can go to first or the other low gears. Also when im just driving normal i feel a slight grind when shifting into any gear its not a grind you can hear.. but you can feel it on the shifter ****.
Letting the clutch out and back in and shifting right away didnt make any difference, also i checked the reservoir and its full! Thanks for the response!
mine does basically the same thing.I just down shift and make sure im in 1st before the truck stops. When your having problems getting into gear do you hear a clunk inside the tranny if you try to go back and forth between 1st and 2nd?
If thats the case its slack in the tapered bearings inside the tranny and it just needs to be reshimmed.
When the main shaft get a bit of slack the tapered bearings let the shaft assymbly fall a bit and it drags along the pilot and you just have to hold the clutch in and hold the shifter in 1st lightly untill it slips in.
Mines doing it and I just havent had the time to pull it to take up the slack.
sorry for the long post.
Is there any difference when trying to get it into first -if the engine is running or not running?? With the engine off-is it easier to get the tranny into first??
