i am sorry for asking this question, i should know the answer. But i dont.
i can't get any info from my drivers side valve cover, pass side just has orange sticker with HP info. is there another way to get tihs info? where is the inspection door/ plate? again sorry for the repet question.
__________________ Josh PPA#83
No spark plugs here
01 F350 7.3psd 5" lift 35'' nitto,CCV,GTP38R,OBA,AHI delete,riffraff FRx kit, bellowed up pipes, DP tunes-60,80,120.AFe stage II intake, Pete's cover,4'' ss exhaust no muffler, 4 gauges, foil delete, tugger kit,6.0 trans cooler.08 diff cover. Riffraff IC boots.
2000 and earlier had forged rods....and there is probably a build cutoff date because some 2000s came with PMRs.Umm IIRC, it was 10/2000 that they changed over to the PMRs, but that is disputed because some later build trucks have forged in them.
Diesel Innovations website used to have a picture of the inspection hole and directions on how to determine what type of rods you have, but its gone missing.
I'm trying to see if I can dig that up for you.
__________________ Lisa Early '99 PSD long bed XLT supercab. 4" Pro Comp suspension lift, 315 BFG AT's on 17" Liquid Metal Gatlins, Hypermax Boost Pyrometer, 4" exhaust, DP Tunes - no start, 60 Tow, 80 Econo, 120 Race, 203* thermostat and billet housing, 6637 w/Pete's cover, CCV, oil crossover Kit.
Yes I have Forged rods, Mike (Tenn) don't. My truck was built 8/2000, his was built 9/2000. I don't know if that is the difference or not. There is a plug right over where the oil filter is that will let you see inside the block. I had to use a piece of 7/16" square stock to get the plug out. It is not 1/4" or 3/8" ratchet. I did put the square 7/16" square inside a 12 point 3/8" socket in order to take the plug out. Once I got the plug out, I still couldn't see the rod nuts. I had to get my wifes magnifying mirror to look into the hole. I also had to bump the starter 5 times in order to see the nuts. There is only about 2 1/2 threads on after the nut. You don't have to drain the oil, just look and find the plug over the pan.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-VB, DP-TUNER LIVE- stock, HI. 40t, 60t, decel, 80t, 80e, 140s, OBA, 203*, billet housing, MBRP 4" SS, Isspro 3 gauge kit, Zoodad, Foil delete, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
well i will have to look. the reason for the question is that i am thinking of putting injectors in my truck. Clay had sad something about stage 1 or 2 not sure what the ratting is on either just dont want to cross the magic HP number and brake something?
No spark plugs here
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
