Does anyone have anything bad to say about the Liberator EGR Delete Kit?
In all honesty I do not know much about the kit, it looks like every other kit.
I installed a kit from FirstCoastDieselPerformance.com
Check it out. In my opinion you get the most for your money with this kit. Clean (hot tanked) intake manifold that is heliarced with new coolant flow passages, a 180* heliarced tube to connect the coolant from the manifold to the oil cooler & a new up pipe without the flex section that might break because there is no more support from the EGR cooler. ALL THIS FOR 630.00 (plus 250.00 refundable core charge until you send your old manifold and up pipe)
From Liberator.......For 600.00 you get a new up pipe, a reroute tube and a piece of hose.
CALL ME CRAZY, but it seems like you get alot more for the money with FCDP.
By the way, if you haven't done your CCV reroute...your current intake is going to look real gummed up and oily....another reason to start with a clean and modified intake.
Just my opinion, but you'll buy what your gonna buy anyway.
Good Luck
Good Luck
I have the liberator egr delete along with SCT from innovative. My EGT's are alot lower than ever before and the truck runs awesome. Even towing my 40 ft 5th wheel RV with an 04 F350 crew cab I very rarely hit 10K on the EGT. It averaged around 700 or 800 while towing. That is impressive.
Good Luck
Good Luck
berick,
Yes your manifold is bad. I had 40k on my truck when I did my EGR delete (I performed a CCV reroute 1k before). The CCV reroute IS A MUST IMO. It will prolong the life of your intake elbow (feeds the turbo), IC boots, Intercooler (IC)....etc etc
Just an example. When I did my EGR delete, I had to replace the elbow that feeds the turbo (right after the air filter) and two iC boots. They were OIL ROTTED! Sure the new boots claim to be oil resistant but who gves a s**t??? The oil vapors are terrible for the intake system. If you do it right you'll be abe to capture the vapors in a sealed (drainable) container and return clean(er) air back to the intake......Do a search you'll find it.
rickatic,
I am so happy with the results I got from doing an EGR delete.....and even happier that I went with a kit from FCDP....First Class product. The only modification I made to mine is I replaced a majority of my hoses with silicone hoses (take heat well, never deteriorate). I changed the hoses that came with my FCDP with silcone hose...The important thing is tho use "shielded clamps" to avoid damaging the hose. Other than that....bolt it in.
rickatic,
I bought one, but once I received it I realized I could have made it.
It would be way too long and drawn out for me to explain how to make it. If you search around this site on a guy named "bismic", he has a picture of it mounted on his truck. I have the exact one. I bought mine through a vendor on another site that I will not recommend. There are several types of CCV reroutes that vary in price and complexity but ultimateley do the same thing. Good Luck
Go to the tech folder and find the ccv reroute. It'll tell ya what to do. But on the other hand you could just go down to your local parts store get some 1 inch id heater hose, about 15 foot, and a hose clamp and take it out of the intake and route under the truck. Put a 3/4 inch rubber compression plug in the intake hole, also at the parts store, and call it good.
