Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers And 5th Wheels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Towing, Trailers And 5th Wheels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-18-2009, 12:35 PM
78bigbronco's Avatar
78bigbronco 78bigbronco is offline
78bigbronco is starting off with a positive reputation.
how thick concrete?
Well I couldnt figure out the best forum to put this one in but u guys with trailers and such I hope have some insight. Building a new pole barn / garage. Want to be able to park a decent size camper trailer, boat, etc in it. building it 14' just to make sure about anything would fit. No plans on tractors or semis or anything. My friends at work are telling me 6" minimum. But then there like well 8" or 12", yeah whatever. Builder is saying usually they just do 4" and if I wanted some extra they would do 4.5". Would that really be enough? It is a pretty huge cost difference between 4" and 6" would something like 4.5" be enough? It is going to have saw cuts or whatever thats called, and steel mesh atleast. Thoughts? Its basically down to if I need to go 6" I'll probably have to shrink the size of the barn since I wont be able to afford it I dont think. I could maybe just cement half of it or somethig for now...
__________________
09 F-350 V10 4x4 6spd CC/8' ordered 5/26/09 delivered 7/6/09
99 F-150 4x4 Reg/Short bed
78 Big Bronco 4x4 (a work in progress)
84 Tbird (351W project still in dry dock)
  #2 (permalink)
Old 06-18-2009, 12:44 PM
J_E_Summit's Avatar
J_E_Summit J_E_Summit is offline
2008 Ford F-250
J_E_Summit is gaining momentum as a positive member of FTE. J_E_Summit is gaining momentum as a positive member of FTE.
As long as its on a good solid foundation with proper reinforcing, 4" should be just fine. Just make sure that it has frequent expansion joints so that it will survive freeze/thaw cycles.
Edit,
I don't know anything about your building codes in the states, but as a designer, that is what we spec for everything short of corrosive situations (salt piles, chemical pits . . . )
__________________
Jason
2008 F250SD XLT Chrome Supercab Long Box 5.4L Torqshift
SCT X3 from 5 Star, IQR Headache Rack, BetterBuilt Box, Custom Deckover
BC Chapter Member
  #3 (permalink)
Old 06-18-2009, 01:38 PM
alchymist's Avatar
alchymist alchymist is offline
"Mifflin Clay"
2008 Ford F-350
alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE.
Did a 24X40 pad for mine back in '88. 4" over floor, but 12" x 12' trench with slope up to floor all way round perimeter. Dug two 12' trenches with sloping sides up to floor right down the middle about where wheels would run. 4' mesh, and 1/2 rebar in all trenches. Never did crack from any vehicles. Did get one hairline crack across back corner, but it never opened up. Funny, it was not anywhere near where vehicles traveled.
“Our liberty is protected by four boxes...
The ballot box, the jury box, the soap box, and the cartridge box.”
- Anonymous
__________________
TRITON V10 - THE BEST KEPT SECRET -
(But word is getting out).
'08 F350 Scab SRW V10 w/ 4:10
07 Gulfstream Prarie Schooner
'05 Escape
' Passed the exam today! I am now a licensed instigator!
  #4 (permalink)
Old 06-18-2009, 02:27 PM
senix's Avatar
senix senix is offline
senix is gaining momentum as a positive member of FTE. senix is gaining momentum as a positive member of FTE.
4" is sufficient as long as you throw some rebar and steel mesh in it. Dad I did his drive way when I was a kid and still no cracks.
__________________
2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Upfitter switches
Ravelco Alarm System, Frontier Extreme FT. Bumper
  #5 (permalink)
Old 06-18-2009, 07:10 PM
spinella's Avatar
spinella spinella is offline
spinella is gaining momentum as a positive member of FTE.
i'm a mason, and i would reccomend 6" but if moneys a issue there are some things you can do to make 4" work for you. use wire in the concrete, that doesnt stop it from cracking but it does prevent it from spreading apart. make sure the base below your concrete is compacted. its a common mistake people make after excavacting. when you order your concrete make sure its 4000psi. here on long island the difference between 3000psi. and 4000psi. is about $6. so its well worth it. as said before make sure you have proper expansion joints. check your local codes. saw cuts don't do anything for expansion, they just give the concrete a good spot to crack. just like the lines in sidewalks. they are there so when the concrete cracks it will travel to the "lines" and stay in there until it hits the edge of the concrete. if you want to figure out how much concrete you'll need its pretty simple, just take your square footage and divide it by 81. that will give you your "yard' # @ 4' deep. lets vus know how you make out.
__________________
2000 f350 v10 lariet-A.R.E. cap
front mounted hidden hitch
SCT -X2 5 STAR TUNING-S&B CAI
2009 wheels and tires-superlift leveling kit
firestone air bags-bilstein shocks
  #6 (permalink)
Old 06-18-2009, 10:27 PM
mudmaker's Avatar
mudmaker mudmaker is offline
2002 Ford F-350
mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE.
6 would be better, but 4 will probably work. If it were mine I would use #4 rebar on a 16 or 24 inch grid instead of wire. Most of the time the wire ends up at the bottom doing absolutely nothing for strength.
__________________
Marc
2002 F350 SRW CC LB 4X4, PSD, 6637, CCV, Pretty much Stock
2002 Excursion Limited 4X4, PSD, 6637, CCV, Gauges, superchip(for now)
  #7 (permalink)
Old 06-19-2009, 12:59 AM
OldRacerGuy's Avatar
OldRacerGuy OldRacerGuy is offline
OldRacerGuy is starting off with a positive reputation.
Like others have said, subgrade prep is just as important as how thick the pad is placed. Evenly, tightly compacted dirt will provide good support to the concrete, where uneven compaction with hard spots and soft spots will provide great places for the pad to crack. Bar is better than wire, wire is better than fibermud, fiber is better than nothing. So good subgrade prep, #3 or #4 bar on 16" centers each way and a full 4" pad will hold up to a lot of weight. Make sure that you get a full 4", the 2x4s used to form many pads are really 1 1/2 x 3 1/2, and I've seen guys set the forms recessed into the dirt a bit, making a 4" pad more like 3".
__________________
92 F350 4x4 crewcab E4OD 460
  #8 (permalink)
Old 06-19-2009, 06:44 AM
Quote:
Well like I said they actually suggested 4.5" for extra strength so I would hope with that detail it would actually be a true 4.5". And I'll ask em about using the rebar and making sure its the 6000# stuff. Thanks for all the suggestions! As for the prep the soil around here is high in clay and does pack pretty hard. The excavator was saying something about a local limestone product I think it was called 311 at is various sized peices down to really small and supposidly it packs so hard it almost forms concrete like substance in itself. Perhaps the combination of all this if done well should hold up good. How about the aprons infront of the doors? Should they be any different than the rest?
__________________
  #9 (permalink)
Old 06-19-2009, 07:04 AM
senix's Avatar
I would make the aprons the same
__________________
  #10 (permalink)
Old 06-19-2009, 07:24 AM
hanklin's Avatar
hanklin hanklin is offline
hanklin has a good reputation on FTE. hanklin has a good reputation on FTE. hanklin has a good reputation on FTE.
during the curing stage,take some old carpet and spread it out then keep that watered as it will strengthen better than if you just water it. It keeps moisture in
__________________
2001 7.3l F-444(Monkey Wrench Racing) PSD 4x4 SC ;stainless ruenel bumper,glasstite,exhaust,superchip autometer cobalt gauges,tymar,sonnax ,zoodad mod:-Line-X , 5er:
even a blind pig finds mud now & again
  #11 (permalink)
Old 06-19-2009, 08:31 AM
rvpuller rvpuller is offline
rvpuller is starting off with a positive reputation.
When we built the metal building that we store our 5ver in all the floor is 4" except where where the trailer axles set that is 8" just in that area, the whole floor has wire mesh also. We had a advantage because we knew what was going to set there and where to strengthen the floor. Our 5ver puts 12K+ in a very small area where the axles set. No cracks in that area after 10 years.
Denny
__________________
2000 F350 Lariat SC DRW V10 4.30 Gears BrakeSmart
Air Lifts 4X2
2003 HH Premier 35 FKTG
BSEG started 4/15/2000
Avon Park Fl for the winter 09-10
  #12 (permalink)
Old 06-19-2009, 11:04 AM
87mh's Avatar
87mh 87mh is offline
87mh is gaining momentum as a positive member of FTE.
High clay content???
Quote:
Originally Posted by 78bigbronco View Post
...the soil around here is high in clay and does pack pretty hard. ...How about the aprons infront of the doors? Should they be any different than the rest?
A high clay content could be a real killer for a pole barn...
In East Texas where the clay is really slick a whole building can noticably creep down a hillside in just a few years...
I would really suggest the contractor dig "bell" holes for the uprights - go deep enough to where the bottoms will be well founded in non-moving soil.
Utilize the uprights to "lock" the building in position - this requires a good perimeter and intermediate trench (as others have wisely metioned earlier).
Make sure your wire mesh is lifted at least 3" off of the compacted base and STAYS THERE during the pour - so often the yahoos working the pour walk all over the wire mesh and push it down to the base - it does absolutely no good on the bottom - the wire is designed to work in tension - all of the tension in a pad is at the SURFACE of the concrete - make sure you spec the placement (and number) of the rebar and wire mesh when you draw up the contract. The base preparation and the concrete is not a place to wimp out on costs when estimating a storage barn - suck it up, spend the bucks, do it right the first time.
__________________
2005 Excursion V10 Limited
Hensley Arrow Hitch Assembly / Jordan 20/20 Direct Proportion Brake Controller
1978 31' Airstream Sovereign - Polished and Rebuilt From Axles Up
  #13 (permalink)
Old 06-19-2009, 12:56 PM
mudmaker's Avatar
2002 Ford F-350
Quote:
Originally Posted by 87mh View Post
Make sure your wire mesh is lifted at least 3" off of the compacted base and STAYS THERE during the pour - so often the yahoos working the pour walk all over the wire mesh and push it down to the base - it does absolutely no good on the bottom.............
To be fair, it is impossible not walk on mesh when pouring, unless you don't have to walk in the mud. That is why I always recommend rebar instead of wire mesh. Rebar you can be placed on chairs and when it is stepped on it stays where it is suppose to. You can pull the wire up and everywhere the guys raking and screeding walk it will be pushed down the the bottom. I have demoed a lot of slabs that have the wire sticking out the bottom, but rarely see rebar
__________________
Marc
  #14 (permalink)
Old 06-19-2009, 07:08 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
Farmer and proud of it
bigredtruckmi is gaining momentum as a positive member of FTE. bigredtruckmi is gaining momentum as a positive member of FTE.
Your 4 inch will be good. I had the redi-mix company mix in some fiberglass (which works like wire) so there is no fuss of keeping the wire in the center of the pour. Check with your cement company but several years ago the fiberglass was the same price as the added cost of the wire. I poured 6 inch because of farm equipment and very heavy trucks. No cracks yet. OH yes do put in a 12 inch "rat wall" around the parimeter to keep the unwanted critters out from under the cement. Also do at least 6 inches of sand under the cement so it doesn't heave from the frost.
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #15 (permalink)
Old 06-20-2009, 12:40 PM
Old Rusty Wrench's Avatar
Old Rusty Wrench Old Rusty Wrench is offline
Old Rusty Wrench is starting off with a positive reputation.
Four years ago I replaced some 4" cement parking slab for MH/5th Wheels. It had cracks and an area 3' x 6' that dropped down about 8" on the edge due to a soft ground and MH wheel weight. Before the repour I had the soft area packed down and the edges dug down 6 to 8 inches by 2 foot and two rebars put in all around. Fiberglass cement was used for its strenght. The slab has had a 42' MH and smaller RVs parked on it. No cracks have appeared to date. Being in AZ frost line is not a problem. I have a 4" slab in WA that is used for RVs that has no steel nor fiberglass that is full of cracks and needs to be replaced like the AZ was done. I know better now!
Tags
1156 , 24x40 , brake , cement , cover , foot , ford , pad , parking , put , replacement , rv , sand , spot , thick , tractor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
