Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers And 5th Wheels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Towing, Trailers And 5th Wheels SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 06-20-2009, 08:49 PM
mudmaker's Avatar
mudmaker mudmaker is offline
2002 Ford F-350
mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE.
Some Fibermesh brand fiber is considered wire replacement, but not rebar replacement. It will help control the cracking, but for actual strength you need rebar. They have some metal fibers that can be spec'd for rebar replacment in some applications, but the cost per yard is significant.
My only issue with traditional fiber mesh is the appearance. A company called buckeye makes a smaller mesh that can not be visually detected and seems to work well. Technically it is not considered a wire replacement, but we had a lot of happy customers use it. Especially decorative applications.
__________________
Marc
2002 F350 SRW CC LB 4X4, PSD, 6637, CCV, Pretty much Stock
2002 Excursion Limited 4X4, PSD, 6637, CCV, Gauges, superchip(for now)
  #17 (permalink)
Old 06-28-2009, 06:02 PM
stevorino's Avatar
stevorino stevorino is offline
stevorino is starting off with a positive reputation.
If you have alot of clay, that means it will expand and contract as it loses and takes on moisture. 4" with #4 rebar both ways @16" on center is good, but you probably want to make sure it will remain ridgid when the soil moves. It would probably be best to go with a deeper slab along the tire path and even thicker where the wheels and jacks will be sitting, like 6" or 8". You could even add another row of rebar along these areas. Do compact the area under the slab with road base to give it a good hard surface sit on. And like everyone has been saying, don't let the guys push the rebar down to the bottom of the concrete. Before they place the concrete everything should look nice and neat. Not like a mess of steel placed wherever they feel like it. I have done parking garages with 6" slabs and 5000# concrete, so don't worry about it too much, you could go with 3000# concrete and I think you'd be fine. Seal it to waterproof it and you're good to go.
__________________
'95 F350 XLT Crew Cab Long Bed 7.3l Diesel E4OD
160K miles
3.55's
2wd
3" downpipe
cat delete
SCMT 1705 (saving for TW chip)
Tags
1156 , 24x40 , brake , cement , cover , foot , ford , pad , parking , put , replacement , rv , sand , spot , thick , tractor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
