Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 06-23-2009, 04:12 PM
Pablo-UA Pablo-UA is offline
Pablo-UA is gaining momentum as a positive member of FTE.
yeah, my engine builder tells me to let engine idle for 10-15 min and drive van with accelerations in 3d ore 4th gear from 1200 to 3000 rpm several times, then to let idle. He sais that I should read temp. gauge to prevent overheating and not to off engine after I ran 2000 rpm before I let engine idle for 2-3 minutes.
  #17 (permalink)
Old 06-24-2009, 02:13 AM
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is starting off with a positive reputation.
That 2000 for 20 is for breaking in just the cam; make the lobes wear in with the flat tappet lifter faces. It helps all engines to do this properly, but is critical for racing engines with aggressive cams.
Engine break-in should follow what you said.
  #18 (permalink)
Old 06-24-2009, 04:28 AM
well, now I leave to Greece and my parts are shipped from USA to Europe. I'll get them a week later when I'll be home ))
__________________
_____________________________________
And makes us rather bear those ills we have
Than fly to others that we know not of?
  #19 (permalink)
Old 06-29-2009, 11:42 PM
jetfiremuck jetfiremuck is offline
jetfiremuck is starting off with a positive reputation.
Pablo I would glaze break the cylinders, clean pistons and rering, replace mains and big ends , bead blast the heads, regrind valves new valve seals gaskets and you are ready to go.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
