Question on upper EFI intake
Old 06-17-2009, 07:40 PM
dotcentral's Avatar
dotcentral
dotcentral is offline
This is on a 91 5.0 in a 91 T-bird.
I need to seperate the upper intake plenum from the lower. Engine is still in the car. Is it just four bolts holding the two halves together? I have all the electrical connections unplugged, and I have bled off the fuel pressure.
I only see four bolts so I think it is the gasket holding it together, but don't want to break anything trying to force it apart.
Help would be appreciated.
Old 06-17-2009, 08:49 PM
82ford302's Avatar
82ford302
82ford302 is offline
there is a intake plaque that says 5.0HO or so on it. there will be 4 allen or torx bit screws holding it on. under that plaque is 2 more bolts you need to take out to get the upper intake plenum off.
Old 06-17-2009, 10:31 PM
dotcentral's Avatar
dotcentral
Thanks for the info, I never would have thought about looking under that.
Old 06-17-2009, 11:03 PM
82ford302's Avatar
82ford302
no prob
Old 06-18-2009, 03:21 PM
jerg_064's Avatar
jerg_064
jerg_064 is offline
On an EFI SBF windsor, I'm pretty sure you'll always have 6 bolts holding the intake plenums together. Here's a GT40 upper, and F-150 type lower.
Old 06-18-2009, 05:03 PM
70torino429's Avatar
70torino429
70torino429 is offline
neither of those pictures shows a gt40 intake...
Old 06-18-2009, 07:03 PM
jerg_064's Avatar
jerg_064
jerg_064 is offline
Yep, my bad... I think that's a regular car 5.0 upper. Still a windsor EFI intake, the diversity helps my point. Here's a GT40(left) and 351w pickup lower in the second pic(far right).
Old 06-19-2009, 09:53 AM
Freaksh0w's Avatar
Freaksh0w
Freaksh0w is offline
I had those pictures saved when Conanski posted them awhile back. I have them that he listed them as (the big 3 pictures):
5.0 HO/ 5.0 Truck/ 5.8w
Which is why the 5.0 HO lower intake helps the 5.0 trucks gain lower torque.
Pkupman82
12-24-2016 10:16 PM
Autumn Koslow
29
02-07-2016 08:01 PM
May Bell
12-27-2011 11:00 AM
91gettaDI
16
11-01-2009 06:46 PM
91Bronc300
22
04-06-2009 08:16 PM
Quick Reply: Question on upper EFI intake
