Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #46 (permalink)
Old 08-18-2009, 03:50 PM
luthrobediesel's Avatar
luthrobediesel luthrobediesel is offline
1997 Ford Ranger
luthrobediesel is starting off with a positive reputation.
Diesel exhaust has NOX in it and thats a greenhouse gas, which is bad. Why do you think they make DPFs, cats, EGR, urea injection? Its all to lower NOX. Well the DPF not so much.
  #47 (permalink)
Old 08-18-2009, 04:18 PM
paulfreda's Avatar
paulfreda paulfreda is offline
paulfreda is starting off with a positive reputation.
Quote:
Originally Posted by luthrobediesel View Post
The planet is getting hotter and the Ice caps are melting. Someone had to start doing something.
We need a big shield to protect the earth from the sun. That's where it's coming from. Currently the avg. temp of the earth has actually cooled over the past several years. We don't hear from the scientists anymore...only the politicians...follow the $$$$$.
  #48 (permalink)
Old 08-18-2009, 05:37 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
While Diesel exhaust in general is *cleaner* then a gasoline engines exhaust, the stuff that Diesel does emit is quite nasty, like NOX and Soot. The EPA found that diesel soot tends to show signs of increased cancer rates.
I wonder how long until gassers will need an exhaust filter? Gas engines do turn their tailpipes black as well - not nearly as quick of course.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #49 (permalink)
Old 08-20-2009, 08:46 AM
73cntry's Avatar
73cntry 73cntry is offline
73cntry is starting off with a positive reputation.
Quote:
Originally Posted by jonesy302 View Post
As far a 7.3, 6.0, 6.4, and now 6.7.....All these engines are good, they are strong, as well as now even quieter, but with the 40-50,000 price tag we all must remember that using quality ford spec oil(we use 10/30 rotella in everything), coolant changes at 20k, fuel filter changes every 10k+ this will allow your diesel to maintain at its peak performance. Installing chips only cause problems, yeah and i know black smoke don't mean its broke! ,but if you build it to break it it will leave you stranded. I know sometimes its hard to keep up with the maintenance but its the only way. I work on em , I know. Parts will always fail, but there is always a reason. Next time you change your oil, feel it between your fingers, when it stains your fingers, you waited too long to change it, even if you were before your milage( how hard do you work it?) We all miss the 7.3 but federal emissions won't allow us to run without egr, and dpf. Ford coolant sucks and breaks down too early and causes all kinds of problems when the coolant looses its lubricity and starts corroding instead of protecting. The new 6.7 is amazing, it will burn dually rubber through 3 of 6 gears. Good will come of the new generation of diesel, but all in time. You don't have to believe me but most of you don't work on em'
So your saying everyone should use 10W/30 oil when changing it. I have a first gen 94 7.3 DIT 5spd manual and I use 15w40 oil. I also live in VA though.
__________________
04 F150 Heritage 4.2
04 Chrysler Pacifica
94 F250 7.3 DI Turbo Diesel 5spd
4x4 ext cab 8ft bed 3in DP, 6637 NO Kitty, DANA 60 Mod
Tags
67 , 67diesel , diesel , ford , injection , spec , urea
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
