V10 blowing spark plus on several cylinders - Ford Truck Enthusiasts Forums
Old 06-17-2009, 03:41 PM
Bowhunter2001's Avatar
Bowhunter2001 Bowhunter2001 is offline
Bowhunter2001 is gaining momentum as a positive member of FTE.
One of my trucks has the V10 in it. I have had cylinder # 9 blow the spark plug 3 times. Other cylinders have blown also. I just picked the truck up being fixed ant Ford and #2 and # 4 cylinders spark plus were fixed. Drove the truck from the shop and before I got back to the store, number #9 blew for the 3rd time. Just paid them over $800 and another cylinder that they charged me a bunch blew. I now have over $3K in this and they are now telling me I need new heads for another $4500.
This has to be a V10 problem I would think. Is there anyway to find out about recalls? the Ford guy says there isn't any. How can my V10 have so many problems?
Old 06-17-2009, 03:53 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
What year is it? Go down to the V10 forum on this site and look around.
It's a "known issue" up until sometime in 2002, and then it became very VERY rare.
3 times on one plug? What did they do? Did they do an insert on it? Or just try to put another plug in and hope for the best?
Sounds a lot like the dealer techs are to blame for the repeats.
Once an insert is done in a hole, it NEVER comes out if it's done right.
Old 06-17-2009, 04:34 PM
Mods, can you move this to the V10 area? thanks
Old 06-17-2009, 04:49 PM
Ricohman's Avatar
Ricohman Ricohman is offline
Ricohman has a good reputation on FTE.Ricohman has a good reputation on FTE.
You need to find another repair shop or do this yourself.
Most that have done a timesert repair or the like never have another problem with that cylinder.
Old 06-17-2009, 05:32 PM
XL1200LTD-Keith's Avatar
XL1200LTD-Keith XL1200LTD-Keith is offline
XL1200LTD-Keith is starting off with a positive reputation.
Old 06-17-2009, 05:49 PM
Krewat's Avatar
Thread moved to the V10 forum
Old 06-17-2009, 06:51 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
I think you should get ahold of these guys and let them fix your plug problems. Some here have used them before. Will cost a lot less than new heads.
Blownoutsparkplug.com
I will say I believe the stealerships screwed up the repairs royally. A repaired plug done right should not blow out especially 2 times after the fix.
Old 06-17-2009, 06:53 PM
BareBones BareBones is offline
BareBones is gaining momentum as a positive member of FTE.
Need to know the year.
Old 06-17-2009, 08:41 PM
Great call!
dkf posted........
" I think you should get ahold of these guys and let them fix your plug problems. Some here have used them before. Will cost a lot less than new heads.
Blownoutsparkplug.com "
http://www.ford-trucks.com/forums/86...ml#post7621227
Old 06-17-2009, 09:02 PM
Quote:
It is a 1998.
Old 06-18-2009, 09:47 AM
Krewat's Avatar
I merged your two threads and deleted two posts to clean it up.
Back to the subject at hand.
Since it's a 98, I'm going to assume it's an E-series van?
Did you ever change the plugs in the past 11-12 years?
Old 06-18-2009, 09:50 AM
Correct E series. I bought the truck with 68K on it so I don't know if the previous guy did.
Old 06-18-2009, 10:09 AM
Krewat's Avatar
I suspect that the iron un-plated plugs are rusting, and the aluminum threads are corroding, and they are working themselves loose.
I don't have an easy answer, except to do inserts on all 10 holes.
If they already did inserts on some of them, and the inserts came out, I'm not sure if another insert is possible. I THINK so, depending on the brand of insert and what the dealer/mechanic did the first time.
++ TIME-SERT SPARK PLUG REPAIR KITS - FORD ++ Spark plug ejection problem blown out blow outs spark plugs blown out spark plugs, ford blown out spark plugs blow out spark plug defect
They don't mention oversize inserts though. But here they do:
++ BIG-SERT Oversized Spark plug thread repair kits ++ spark plug thread repair for oversized holes previously repaired spark plug holes threads stripped
Old 06-18-2009, 10:29 AM
Duplicate read next post
Old 06-18-2009, 10:33 AM
2/19/08
Took truck into dealer for miss, rough idle. Codes came up. Misfires on 1 and 2 cylinders. Replaced 1 and 2 coils on plugs. replace oxygen sensor. checked codes, ok. $569.61
3 days later 2/22/08.
Excessive noise from engine and runs rough. Found #9 spark plug blown out of cylinder head. Re tapped and installed helicoil.
Took cylinder head off and found debris on cylinder #9 piston. Removed debris and reassembled. Checked ok. total bill $2627.35
1/12/09
Took truck back for excessive engine noise and engine running rough. Found helicoil and spark plug blown out of #9 again. Installed oversize helicoil. Replaced broken coil on #9 cylinder. $202.63 repair
6/5/09
Took truck back for excessive noise and runny rough. Replaced #2 and # 6 coil on plug and spark plugs. Welded crack in exhaust. All bolts broke off when removed manifold. Drilled and tapped and installed new bolts. $812.75 repair
Picked up truck and drove it 30 miles and excessive engine returned. Truck was towed back to dealer and they told us #9 plug blew out again. Needs new heads. Repair would cost $4500.
Spark plug on cylinder 4 is sitting level with hole (bought with misfires) thegreatgate 1999 to 2016 Super Duty 6 04-04-2016 09:06 AM
V10 Spark Plug Blowout!! Josh Ludwig 1999 to 2016 Super Duty 27 09-19-2014 05:15 AM
Oil Consumption -- All of a Sudden thollist Modular V10 (6.8l) 9 08-05-2009 09:07 AM
Excursion Spark plug blew 2002 Excursion V10! bigt3725 Modular V10 (6.8l) 13 03-04-2009 10:11 PM
Misfire #3 & #7 Cylinders, 1997 Triton V-10? cpenzien Modular V10 (6.8l) 19 08-25-2008 11:36 AM
Tags
2008, coil, ford, heli, helicoil, loose, pack, plug, plugs, rethreading, solid, spark, truck, tsb, useing, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
