V10 blowing spark plus on several cylinders - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 06-25-2009, 09:40 AM
Bowhunter2001's Avatar
Bowhunter2001 Bowhunter2001 is offline
Bowhunter2001 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by mwsF250 View Post
Wow, classic nightmare story. Sorry to hear it. Clueless gorillas should not be allowed to work on aluminum heads! There are so, so many stories out there. People used to working on old idiot proof iron headed engines should retire or get some education before playing with aluminum.
Turns out some CG installed a Heli-Coil in mine after the PO overtorqued plugs and stripped them. Heli-Coils are awesome for many things, but NOT sparkplugs. Yes, it blew out.
You can get rebuilt cylinder heads from Clearwater Cylinder Heads with solid inserts properly installed in all plug holes for under $1K for the pair. Check it out. I did and have been pleased so far. Only 10K miles, but lots of towing with no issues.
Thanks for the info.
  #32
Old 06-25-2009, 10:58 PM
Pinky Demon's Avatar
Pinky Demon Pinky Demon is online now
Pinky Demon is gaining momentum as a positive member of FTE.Pinky Demon is gaining momentum as a positive member of FTE.
Could someone please tell me or link me to a thread with the complete story on what exactly happens when these coil ons blow.
  #33
Old 06-26-2009, 09:53 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
You will know it when a plug blows. It often times takes the COP with it. My neighbor across the street had two blow on his 97 F-250LD. I was outside when he came home with the blown plug. It sounded like an air compressor running with no manifold on the top of it.
  #34
Old 08-18-2009, 09:43 AM
hotrod4x5 hotrod4x5 is offline
hotrod4x5 is starting off with a positive reputation.
Is there any update to this? What did they end up doing for you?
I had a plug blow out on my 02 at about 45,000 miles. Original plugs. I had a service contract from the Toyota dealer where I bought it, and they paid Ford to replace the head on that side. $3200.
  #35
Old 08-19-2009, 09:16 PM
They tried to use another coil and it didn't hold. I ended up getting another head for $500 installed.
  #36
Old 12-27-2009, 01:57 PM
Quote:
Originally Posted by spark plug doctor View Post
Spark plug blowouts is a common problem on the Triton engines. (4.6L/5.4L/6.8L) In any case, this repair can be performed on the vehicle without removing the cylinder head. Heli-coil products should NEVER be used on a Triton engine. Heli-coil "save-a-thread" or the Heli-coil "coil spring type insert" do not work on these engines. If a Heli-coil product has been installed in your engine and fails there still are more options available in doing the repair! I've done at least 600 Triton spark plug repairs and as of yet have never had to remove the cylinder head. Dealerships and garages like to remove and replace the heads because it generates labour and part sales.
The 3 Valve Triton also has spark plug related issues, but in this version it doesnít leave you stranded on the road. Spark plug issues come to surface when you try to remove them. At this time you may break one or all of the plugs in your efforts to remove them. Once again do not let anyone remove the cylinder head to do this repair. This repair should be straight forward for an experienced tech.
What Iím trying to stress to Ford owners is simply that the cylinder head should NEVER come off to do any spark plug related issues!
You might find this posted somewhere else, if so, could someone merge them for me?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Your reply is missing one key point... how do YOU do the repair?
  #37
Old 12-28-2009, 02:14 PM
Old Time RV'er Old Time RV'er is offline
Old Time RV'er is starting off with a positive reputation.
Where are you located and how do I get ahold of you?
  #38
Old 12-28-2009, 03:29 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Had to remove this guy's posts. He is actively trying to sell his services and he's not a sponsor. Site rules.
  #39
Old 12-28-2009, 03:53 PM
I agree, he should be a sponcer if he is trying to sell services.
It is only fair.
  #40
Old 11-11-2013, 04:13 PM
jackstand jackstand is offline
jackstand is starting off with a positive reputation.
Why doesnt Ford admit this is a defect
My 2000 F250 has 155,000klms or about 100,000 miles. It had the plugs changed at 90,000 klms they were as new. Ive owned the truck since new and have used synthetic from the 600mile break in. I was a great fan of the truck until a week ago when it blew a plug and the threads out of the head. Pathetic design where by the plug only screws in about three threads. Fords answer was save your repair bill in case they ever have a recall. I recently bought an Coachman Epic Motorhome. I was hesitant because it had a GMC engine instead of the Triton V10 I had grown to love over the years. Smooth and powerful. Well as it turns out I am glad that I only have one lemon and not two. I am no longer an unqualified Ford fan.
  #41
Old 11-16-2013, 10:37 PM
NovaNewfie's Avatar
NovaNewfie NovaNewfie is offline
NovaNewfie is gaining momentum as a positive member of FTE.NovaNewfie is gaining momentum as a positive member of FTE.
Quote:
Ford "fixed" the problem halfway through 2002 year by putting more threads in the holes. They made a blunder in '05 when they started using the long plugs in the aluminum heads where by the smooth shank on the plug below the threads build up carbon and break off when removing them. There are a few TSB's to deal with these newer '05 + plugs.
Spark plug on cylinder 4 is sitting level with hole (bought with misfires) thegreatgate 1999 to 2016 Super Duty 6 04-04-2016 10:06 AM
Puking Up Spark Plugs. Spark Plug Blowouts. _Rick_ 1999 to 2016 Super Duty 55 07-19-2015 11:28 AM
V10 Spark Plug Blowout!! Josh Ludwig 1999 to 2016 Super Duty 27 09-19-2014 06:15 AM
Popped out a spark plug 03prerunner Excursion - King of SUVs 7 08-26-2014 04:35 PM
1999 E-350 Cylinder head help! bb1982 1968-2013 Full Size Vans 9 11-04-2012 08:36 AM
Tags
2008, coil, ford, heli, helicoil, loose, pack, plug, plugs, rethreading, solid, spark, truck, tsb, useing, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
