accidently put gasoline engine oil in my 6.0 diesel - Ford Truck Enthusiasts Forums
Old 06-17-2009, 12:56 PM
seth1's Avatar
seth1 seth1 is offline
seth1 is starting off with a positive reputation.
so i was gonna do my first oil change on my 03 f350 with 6.0 powerstroke and i didnt know much about diesels and i had asked a guy at fleet farm about oil and he said it didnt matter what i used so i got penzoil 10w 30. about 5000 miles later i was pulling about 12000 pounds and all the sudden i lost power and it was like an injector was out. i ended up replacing two injectos and the fuel pump. and then it still wasnt normal. since i didnt have the money to keep changing injectors i just took it home and parked it. then a month or so later my dad was talking to his buddy and said he had same kinda problems like injectors were out and the shop he took it to said bad oil could make it run like that. so i changed my oil and it ran fine for awhile then acted up again so i just kept changing it. on my 5th time in about 5000 miles and evertime it acted up i would just change it and it would come out of it. now this time it doesnt seem like its gonna. could i still be working out all the gasoline oil or could i be looking at bigger problems?? any ideas woulld be appreciated. thanks
Old 06-17-2009, 02:00 PM
KSCRUDE KSCRUDE is offline
KSCRUDE is starting off with a positive reputation.
I seriously doubt if 5w30 oil caused any problems with your truck. And diesel oil other then weight will usually have a little more detergent and that is about it. I run diesel oil in all my lawn mowers and 4 wheelers and small engines. And it is 15w40 but most of this only sees mostly hot weather running but not all the time. Your injectors are probably getting tired. 5w30 is a little lite for a diesel but i doubt if that was your problem. How hot was it when u were pulling the 12k and had the problem?
Old 06-17-2009, 02:01 PM
12ozd's Avatar
12ozd 12ozd is offline
12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold
With 5 oil changes in 5000 mi.,doubtful that is your issue now.
I also doubt 1 oil change with 10/30 would hurt anything either.
You have the correct oil in now,I would look somewhere else for a problem.
Old 06-17-2009, 02:05 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
I don't think it ever was the problem with the oil.
Old 06-17-2009, 03:55 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
High-pressure engine oil is used to fire the injectors. If you use the wrong weight oil, it CAN cause problems.
Thread moved to the 6.0 forum, you'll get lots of help from these guys
Old 06-17-2009, 04:21 PM
jimmy-six's Avatar
jimmy-six jimmy-six is offline
jimmy-six is starting off with a positive reputation.
Didn't you read your manual about oil before the first change?....Try a gallon of "Hot Shot Secret" it's helped a lot of folks here....
Old 06-17-2009, 05:02 PM
seth1's Avatar
when i was pulling the trailer it stayed right in the normal range where it usually did when driving.
what kinda problems?? injectors for sure? i cant see how an injector can go from bad to ok. i didnt think was a such thing
i tried a bottle of that hot shot a lil over a week ago and then last weekend it started doing the same thing again. so im kinda lost with what to do...
Old 06-17-2009, 06:57 PM
heavyiron's Avatar
heavyiron heavyiron is offline
heavyiron is starting off with a positive reputation.
Just remember that all these "opinions" are just that. Personally, my "opinion" is that given that your truck is 7 yrs old, has the earliest itineration of injectors and you ran the wrong oil weight in it may all have combined to cause the issue(s).
I think injector problems are very hit and miss. Some here have terrible problems and others dont ever seem to have any problems so who knows exactly.
Good luck with it anyway. Look on the bright side, you only have 6 more injectors to replace and they'll all be new!!
Old 06-17-2009, 07:22 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.
When was the last fuel filter change?? Fuel pressure/volume will make the engine run like it is starved and at MAX loading it could have starved the fuel system. Plus having the wrong oil compounded the problem.
Old 06-17-2009, 08:48 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is online now
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
IS it the type of symptom some are reporting when the wiring harness has a short due to chafing on the engine block ?
Old 06-17-2009, 10:45 PM
JaySVX's Avatar
JaySVX JaySVX is offline
JaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to all
Wow, I had no idea there was special diesel engine oil... I put in regular Rotella-T 5w-40 oil a while back, but did the fuel filters at the same time, and have had zero problems with it.
Old 06-18-2009, 05:50 AM
ljutic ss's Avatar
ljutic ss ljutic ss is offline
ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.
I think all Rotella T 5W-40 is diesel oil.
Old 06-18-2009, 09:28 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is online now
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Quote:
Just like 15w-40 is diesel oil. So no worries...
Old 06-18-2009, 10:25 AM
supertruck60 supertruck60 is offline
supertruck60 is starting off with a positive reputation.
Hot Shot's Secret may help!
Quote:
Hi,
The 6.0 liter has a problem with stiction due to the breakdown of the engine's oil.
We make an oil additive, Hot Shot's Secret, that was designed for International to address this issue. It cleans the oil side of the injectors to help eliminate this and restore the function of the engine's fuel delivery system. If a problem has been diagnosed with the injectors we always recommend running the treatment before replacement.
I am reposting this article that we wrote to flesh out what the problem is and how we can help.
Feel free to call us anytime with any questions that you may have.
Best Regards,
Dan
How To Solve Power Stroke Diesel Truck Injector Problems Inexpensively
Hot Shot's Secret has finally solved the common and costly fuel injector problems diesel truck owners have lamented for years.
To increase the efficiency in modern diesel engines, manufacturers have increased the pressure at the tip of the injector. This increase provides for a better, more efficient burn with added power. Older injectors would put out 1,200 psi at the injector tip but the new diesel engines put out 26,200 psi at the tip. To achieve this increase in pressure the manufacturers had to tighten the tolerance inside the injector. This increased the friction and temperature. The higher temperatures have a burning effect on the engine oil. A layer of oxidized oil and additives form, slowing down the injector and eventually stopping it altogether.
"Injectors in the diesel truck engines have a high failure rate," says Chris Gabrelcik, lubrication engineer, CEO of Lubrication Specialties, Inc. and the creator of Hot Shot's Secret. "Injector issues cause slow start-up, rough idling, hesitation, and lack of power because the injectors aren't firing properly." Until now, owners had to replace their existing injectors, often spending up to $2,500.00, with no guarantee that the problem would not occur in the future.
An amazing 86% of the time, Hot Shot's Secret solves the problem completely, and for the other 14% it has made a significant improvement. "We've got a money back guarantee and if it doesn't work, we'll credit you," says Gabrelcik, who acknowledges the fact that in some instances the product might not work because of other mechanical failures.
Originally created for International Truck and Engine, Hot Shot's Secret is an additive made from a combination of detergents and dispersants. Once added to the vehicle’s crankcase, Hot Shot's Secret removes build-up, the coking and varnishing left behind from overheating of the engine’s oil. "It's the only thing you can put in your engine that will clean it out and actually solve the problem," says Gabrelcik, who spent two years sending dozens of different formulas around the country to be tested in various terrain and weather conditions. The final product was rolled out in November 2005.
In addition to the improved injector performance, Hot Shot’s Secret’s formula will also clean the deposits in the engine and turbo and will fortify existing oil, thus helping it to work more effectively. It only takes 64 ounces of chemical to clean 100,000 miles of build-up. 32 ounces every 3-4 oil changes will prevent the problem from recurring. Lubrication Specialties has customers on record with 500,000 miles on their trucks and are still using the original set of injectors.
Gabrelcik, who has been in the industry for over 14 years, founded Lubrication Specialties in 1997. He has extensive experience working with vibration analysis, oil reclamation, and lubrication consulting with countless national and local companies. For more information, please call 800-341-6516 or visit www.lubricationspecialties.com
Old 06-18-2009, 11:54 AM
seth1's Avatar
since the problem occured i've changed the fuel filters about 3 or 4 times..
i've heard about the wire harness problems and when i had it in a shop they said the harnesses looked fine.
now yesterday i started it up and it ran fine for about 20 seconds then started running like an injector was out. now im thinking maybe im having problems with the inside of my tank breaking down. i have heard some stuff but not alot. could this be possible? can i just un hook my fuel lines to the tank and use air to blow them out?
Now I Know What a 6.0 Costs to Replace JohnnyRockit Excursion - King of SUVs 54 01-16-2017 09:00 PM
6.0 HPO leak and fuel in oil Crazywesc 1999 to 2016 Super Duty 8 09-26-2016 10:56 PM
Slow/now cranking and no codes being thrown Cms300 6.0L Power Stroke Diesel 10 06-07-2016 01:12 PM
Big Trouble fordguru23 1987 - 1996 F150 & Larger F-Series Trucks 14 02-12-2016 02:32 PM
injector contribution ballance fault on two reman injectors jlo84truck 6.0L Power Stroke Diesel 6 12-01-2013 11:12 PM
Tags
2003, 60, diesel, engine, excursion, ford, gas, gasoline, oil, powerstroke, problems, put, small, stiction, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
