Haven't replaced a clucth for many a year. Help- how do you disconnect the hose that goes to the throwout bearing. It seems to wiggle but I cannot figure it out. Any tips for this job would be appreciated.
If you look closely at the connector, you will see a grove around it. Get a small flat screwdriver and use it to slide the outer part of the connector away from the slave. Then it should just pull off of the slave.
