Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-17-2009, 08:40 AM
WATTSUP!'s Avatar
WATTSUP! WATTSUP! is offline
WATTSUP! is starting off with a positive reputation.
In desperate need of wiring help!
I'm in the process of trying to start my new engine (434 stroker) and the starter will not even turn over. It is a '78 bronco and no longer using the stock ingnition module and now using a Pertronix Ignition System. Can anyone provide some detail help in order to see if I have wired this thing up correctly? What I have done is use the white wire which came from ignition switch to the old ignition module and wired it to the positive side of the coil and from there ran a wire to the ignition side of the starter solinoid for a "hot" wire. Thanks in advance............
  #2 (permalink)
Old 06-17-2009, 10:09 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold
"Will not even turn over". That means the engine is not turning when you spring the key over to start? If that's the case, you do not have a ignition problem(yet). The keyswitch sends power to the neutral safety switch, and then to the starter solenoid on the fender, and this wire is red/blue the whole way. Once the solenoid on the fender gets voltage, then the starter will turn over.
About the ignition; I am not sure you used the correct wire, but to make sure, put a meter or a testlight on the coil +, and the other end on the engine block, and make sure you have voltage at the coil in the run position and the start position of the keyswitch.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 06-17-2009, 10:28 AM
WATTSUP!'s Avatar
Checked the voltage with the key in the run position and had 12 volts. What I was told to do was run the white wire to the coil and the red/blue to the solenoid (ignition terminal on solenoid). Per the wiring diagram the white is from the ignition switch and the red/blue is the neutral safety switch. I'm going to try these changes that you have mentioned here in about an hour. I will pass on some feed back. If you or anyone else has anything else to add by all means do so! I dont want to mess anything up on this beast!
  #4 (permalink)
Old 06-17-2009, 11:37 AM
subford's Avatar
subford subford is offline
subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE.
Well you should have wired it like this:
http://i54.photobucket.com/albums/g9...78Ignition.jpg
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #5 (permalink)
Old 06-17-2009, 04:08 PM
WATTSUP!'s Avatar
Tried again with no luck. Even tried to jump the solenoid and starter still didnt crank! I drew a diagram to help aid those to see what I have done let me know if it helps. Sam I will email you what I have drawn.
  #6 (permalink)
Old 06-17-2009, 04:51 PM
subford's Avatar
Use a volt meter when you jump the solenoid across all the points and that will tell you if you have a bad battery cable (ground, power or starter) or the starter. If the meter reads any voltage you have found the bad point (part).
__________________
subford@gmail.com
  #7 (permalink)
Old 06-17-2009, 06:18 PM
WATTSUP!'s Avatar
We are good there. Have new starter, solenoid, cables (all of them). Just think I'm missing something. Not even sure its wired right now!
  #8 (permalink)
Old 06-17-2009, 07:15 PM
Franklin2's Avatar
What happens when you jump #3 to #5 in the diagram above? #5 is the "s" terminal which means start. I would not hook the red/blue to the "i" terminal, it needs to be on the "s" terminal.
__________________
Dave F
  #9 (permalink)
Old 06-17-2009, 08:19 PM
WATTSUP!'s Avatar
Ok, that is what i have going now. The red/blue is going to the "s" terminal on the solenoid. You can here the solenoid kick in when you turn the key and the starter still will not crank. I tried to jump the solenoid from the battery side to the "s" terminal and still nothing! Just hear the solenoid click once and no starter engagement. Is there some thing Im missing? This starting to drive me NUTS! Thanks for all the help by the way guys!
  #10 (permalink)
Old 06-17-2009, 10:56 PM
subford's Avatar
As I said above go point to point with a volt meter.
Taking the diagram above put one probe on 4 & 2 and see if you get a reading when the solenoid clicks. If you get no reading then move to points 1 & 3 and then 6 & 7.
If you do not get any reading at any of the two points above then take the starter back and get another one.
__________________
subford@gmail.com
  #11 (permalink)
Old 06-18-2009, 08:19 AM
WATTSUP!'s Avatar
Will try this evening.
  #12 (permalink)
Old 06-18-2009, 09:10 AM
subford's Avatar
You might also try point #1 to #7.
And by the way point #1 & #2 are the center of the battery post and not the cable clamp.
Point # 4 is on the engine block its self and not the end of the cable.
Point # 7 is the center of the stud on the starter and not the end connector.
__________________
subford@gmail.com
  #13 (permalink)
Old 06-18-2009, 09:19 AM
WATTSUP!'s Avatar
10-4. I will try today after work and post back the results.
  #14 (permalink)
Old 06-19-2009, 08:39 AM
WATTSUP!'s Avatar
Thanks for everyones help! Got the animal running last night and let me tell you she is a BEAST! Now I can't wait to try her out in the mud!
  #15 (permalink)
WATTSUP!'s Avatar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
